Go to Post John is the king of vague, but then again he looks much better at a distance than he does up close :D - Rich Kressly [more]
Unread 10-02-2011, 22:32
Re: Line Sensor
Originally Posted by Robototes2412 View Post
Its a digital input, hook up the brown to the negative and the blue to the positive, the black is normally closed and the white is normally open. Hack a pwm cable so that the black and white line up (read: soldering iron).
I hope nobody follows this advice. It's completely wrong.
Brown is the positive supply to the sensor, and needs to come from the red terminal of a 20 Amp circuit on the Power Distribution board (or from an output on the solenoid breakout if you want to use 24 volts instead). Blue is the power return (ground), and should come from the adjacent black terminal on the Power Distribution board.
Either black or white can be connected to the SIGnal pin of a Digital Input on the Digital Sidecar. The LabVIEW autonomous line-following sample code expects the white wire.
