Go to Post Jeez, I love my job! :) - dlavery [more]
Unread 05-02-2011, 17:05
pottsrulz3461 pottsrulz3461 is offline
FRC #3461
pottsrulz3461 is an unknown quantity at this point
Bridge Mode connection
Hey the member of team 3461 are having trouble connecting the robot and computer through bridge mode. but ap mode works just fine.
Any suggestions?
Unread 05-02-2011, 17:50
FRCTEAM1847 FRCTEAM1847 is offline
FRC #1847
FRCTEAM1847 is an unknown quantity at this point
Re: Bridge Mode connection
There is no need to utilize bridge mode unless you are just testing to make sure that it works or you're trying to communicate wirelessly with a desktop computer. The only time the D-Link is required to be in Bridge mode is at an actual competition. Are you broadcasting wireless from a router connected to your computer with SSID 3461? If so, have you configured the bridge to connect to SSID 3461 (with any security that you have put in place of course)?
Unread 10-02-2011, 21:58
FRC #3461
Tanks for the advice but we have tried all of that. We have triple checked the connection and it s all set up right. Thanks anyway
Unread 10-02-2011, 22:01
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Are you using wireless or have you wired it?
Unread 10-02-2011, 23:03
Don't use bridge mode.
Unread 10-02-2011, 23:16
To use the DAP in bridge mode, you need a wireless access point for it to connect to, and you need to configure about twice as many things as you had to for AP mode, half of which are not in any of the setup instructions because you're not expected to be using bridge mode unless you're at a competition event, and all the configuration is intended to be taken care of for you by a special computer workstation dedicated to the task.
Just use the DAP in Access Point mode, okay?
