Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 10-02-2011, 23:28
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Easiest way to route ~10-12 feet of wire on a telescoping lift?
Depending on what gauge you need, curly extension cords (or other curly cords) are another option. http://www.acehardware.com/product/i...ductId=1286132.
I've never tried it but there also a lot of retractable power cords on the market that might be hacked to get rid of the ratchet. An example is at http://www.amazon.com/Cables-Unlimit...98448&sr =1-1
Unread 11-02-2011, 02:30
Use that spiral-type wire wrap to bundle all the wires together. Attach one end to the highest fixed point on the lift, and the other to the top.
That bundle could weigh about 5 lbs, though. Trust me, 330 did that in 2004 to run some wires and pneumatic tubes to the top of our 10+ foot lift. Let's see... 2 wires for the Van Door motor (slider), 4 wires for the two Globes (upper arm section), 2 pneumatic tubes (the piston to extend the upper arm section). Oh, and the globe wires and pneumatic tubes had to go over the top of that arm's pivot... Other than being really heavy (the aforementioned 5 lbs estimate), it worked pretty well.
Unread 11-02-2011, 03:30
Andy A. Andy A. is offline
Getting old
FRC #0095
In addition to using some sort of wire 'wrap', make sure to leave service loops at any sort of pivot or extension area. To keep the service loop out of the way when in it's slack condition, try using a bit of latex tubing to pull it away from things like chains or pinch points.
Unread 11-02-2011, 03:35
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
The energy chain is one way to go. So are coil cords, non-ratcheting cord reels (you can get them like that, no hacking required). Bundling everything together with spiral wrap works, some well placed elastic strap will keep the bundles from swinging around too.
Unread 11-02-2011, 07:30
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
What we have done in the past and will most likely do again this year is use the following method attached.
The top pulley is attached at the top of your fixed mast. The bottom pulley is attached at the bottom of your telescoping stage. This allows you to have the full length of cable/wire you need and manage it well.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 11-02-2011, 08:00
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We had a bit of experience with this with our elevator in 2008. At first, we secured it as a bundle like EricH talks about. At our first competition, however, we discovered the drawbacks of this method - You have no control at all where the bundle goes. As a result, we ended up with the bundle repeatedly being pulled through pinch points and causing the elevator to jam.
So at our second competition, we switched the bundle our for energy chain. Now, its path of travel is fully defined and controlled, and the elevator works flawlessly every time. We are definitely using energy chain on our elevator this year.
The curly cords Dale mentions are pretty interesting... I would worry about it getting stuck under our elevator and keeping our manipulator off the ground. other than that, it certainly does seem like it would take care of keeping itself nice and contained near the elevator!
Unread 11-02-2011, 09:00
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Have looked at a 1038 robot with this system I can attest that it works very well. I would recommend it if you can make it work.
In the past we have used a couple of retractable lanyards (the small, light weight kind) attached either to the first two stages of a telescoping arm or to the middle and top of the outermost piece. The other end is secured to the wire/tubing bundle. As it extends they extend and keep the bundle from dangling or drifting into the lifting mechanism and when the arm/lift retracts they pull their part of the bundle back out of the way.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
