Go to Post Our club visited the Seattle Regional this week and they all have the FRC bug now. May God have mercy on our souls... - Rick TYler [more]
Unread 11-02-2011, 00:18
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
FTC Motors and Minibot
Our minibot team says that if we gear the motors to the wheels 3:1, the minibot won't have enough torque to get up the pole. Doesn't the motor gain torque by gearing it down like that, 3:1? Shouldn't the minibot climb the pole better if it is geared down than if the motor is attached directly to the wheel?
Unread 11-02-2011, 01:24
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: FTC Motors and Minibot
Most likely a misunderstanding on which way the energy is being transferred.
Or they think you need to gear it down more..
Unread 11-02-2011, 01:44
AKA: Ty
Gearing 1:3 from the motor to the wheel does, indeed increase the torque, doesn't it? Or is my thinking wrong alltogether?
Unread 11-02-2011, 02:19
It depends on direction and counting method.
For the following, the direction is assumed to be motor to wheel.
1:3, counted in revolutions/time: the wheel spins 3x faster than the motor. (Or: for every revolution of the motor's gear, the wheel's gear has 3 revolutions.) More speed, less torque.
1:3, counted in gear teeth: the motor spins 3x faster than the wheel. (Or: the wheel's gear has 3x as many teeth as the motor's gear.) More torque, less speed.
3:1, counted in revolutions: motor 3x faster than wheel.
3:1, counted in gear teeth: wheel 3x faster than motor.
3:1 in gear teeth is roughly equivalent to 1:3 in revolutions; 1:3 in gear teeth is roughly equivalent to 3:1 in revolutions.
I think it's a counting method miscommunication--they're counting the gear teeth (lightning fast wheel), and you're thinking revolutions.
Better get together and figure out your counting method...
