Go to Post your sense of humor - don't leave home without it. - JaneYoung [more]
Unread 09-02-2011, 23:24
toolgirl's Avatar
toolgirl toolgirl is offline
AKA: Kaitlin
FRC #0233 (The Pink Team)
toolgirl is an unknown quantity at this point
Red face Team 233 Teasers!
The Pink Team's current minibot in action (high-speed/ covered with a sheet of paper version). And the battery was getting kind of low... Enjoy!
http://www.youtube.com/watch?v=QQFSIvAtrnc
Also, we've decided to make the entire robot out of plywood this year...
http://www.youtube.com/watch?v=IY6r5y09H2c
not really...
Unread 09-02-2011, 23:30
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: Team 233 Teasers!
Do you know what the frame rate of the mini bot video is?
Unread 09-02-2011, 23:56
toolgirl's Avatar
AKA: Kaitlin
I believe it was shot at around 128 fps (but is now at 30 fps...)
If I'm correct...
(hint: more accuratly 128.5714 fps... I actually just worked the math backwards as I know the 'magic number' of the actual length of time the minibot took)
Unread 10-02-2011, 00:12
1.3 seconds? Wow. That's freakin the greatest I've seen so far.
Unread 10-02-2011, 16:34
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
The clock at the bottom shows around a 1.3 seconds delta from start to finish. Strange how it counts time down instead of forwards though...
Unread 10-02-2011, 18:18
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
I know but its not like we'd ever film something and play it in reverse now would we haha?????
Unread 11-02-2011, 01:13
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Our minibot takes like 12 seconds.. if we play the video backwards. Going up is around 3 seconds.
Unread 11-02-2011, 07:16
toolgirl's Avatar
AKA: Kaitlin
Then again, I am able to reverse clips and retain the same length of the video... or speed it up.... or slow it down...
