Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 11-02-2011, 06:31
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Deploying Code
Quick Question. We were having some problems. We are using labview, and want to run the code before sending it over wirelessly. We know to connect and ethernet cable from the classmate to the first port on the cRIO. We tried this and had some errors. Do i have to change any internet settings? How do i go about doing this task?
Thanks
Unread 11-02-2011, 06:45
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Deploying Code
Go to the KOP website here: http://www.usfirst.org/roboticsprogr....aspx?id=18530
and read the manuals that are posted there. They will take you step-by-step through the process.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 11-02-2011, 07:18
FRC #4272
Re: Deploying Code
Thanks for the fast reply. Which specific manual should I look out?
Unread 11-02-2011, 09:19
Re: Deploying Code
Look for the one(s) that would address "some problems" and "some errors" that you're getting. Without getting more detail from you about the trouble, good advice is hard to give.
