Re: Rule 33 Robot
Quite frankly, there's many posts that I don't answer simply because it has been answered a day or two ago. I get tired of doing the homework for someone else, and I'm not surprised Eric has as well. It's quite something different if someone says, "We looked and couldn't find ..." or "The rule says [xxx], does that mean ...". Those questions I will look at and will give an opinion if I have one. That not only helps the fellow user, but helps me in my understanding of the rules. |
Re: Rule 33 Robot
No one's obligating you to answer questions - all we're asking is that people don't treat rookie teams like they're complete idiots because they're confused. If you're tried of answering the same question repeatedly, and can't tell someone to check the Q&A and Manual in a nice way, you can just ignore the thread.
Re: Rule 33 Robot
I don't assume rookie teams are helpless, but I do have empathy for how confusing some of the rules can be. Every team - rookie and veteran alike - should have someone devoted to reading the Q&A. It doesn't take that long. The GDC generally answers a handful of questions at one time; the most I've seen is roughly a pageful on any given day. And they don't answer questions every day. That way when a team has a question, they can ask their Q&A specialist if they recall anything about that topic. Or you might have more than one Q&A specialist, each devoted to a different section of the Q&A, to spread the workload if it's too much for one person. |
Re: Rule 33 Robot
I was not talking about you. I was just clarifying what I meant for you. From what you say that is the perfect thing to do, answer the question and then remind them of where they can find the answers themselves.
Re: Rule 33 Robot
You know what would help? A search system that can handle simple "and" and "or" queries. (If the functionality exists, I've not figured it out, so it must not be all that intuitive.) Limiting search capabilities to one-word search phrases is just...well, rather useless.
Of course, we're just a rookie team, so what do we know... |
Re: Rule 33 Robot
Re: Rule 33 Robot
Plus, you seem to miss my point: With all the griping about people not finding various threads, the obvious solution is to spend a small amount of time supporting boolean search functionality. |
#8
Re: Rule 33 Robot
For example, I just did one on "minibot AND legal". I turned up 4 pages worth of threads, with both words highlighted in those threads. There used to be a note on one of the search pages that boolean worked--somewhere along the line, it disappeared. You can search any number of words. Now, on your rules question: What is the definition of Fabricated? It's a part of some form (component or mechanism) that has been modified somehow into its final form for robot use, completely or partially. (Paraphrase of the definition in Section 1.6) As such, that collection of parts on the acrylic sheet would be a Mechanism, a Fabricated Mechanism (note the definition of Mechanism in the same section). As it is Fabricated, it would indeed count against your Withholding Allowance. P.S. If you have a suggestion for the webmaster, there is a subforum to make it in: http://www.chiefdelphi.com/forums/forumdisplay.php?f=8 |
#9
Re: Rule 33 Robot
Do COTS control devices mounted on an acrylic sheet count as a FABRICATED assembly for withholding allowance purposes? The blue-box comment in the rules docs seems to indicate the ruels favor continued programming work on the control interfaces after the bot ships...so we are wondering if we need to disassemble our collection of COTS interfaces in order to avoid our collection classified as a FABRICATED assembly.
#10
Re: Rule 33 Robot
Go search google. type in multiple words. Lets do the search, rookie team When you look at the URL (web address), it says http://www.google.com/#hl=en&sugexp=...188ee12107320c The part i want you to focus on is the rookie + team part In any search engine or forum, to search for more than one word, use Rookie + team, replacing those with words that you want to look for. EX i want to look for Blarglefish and Team 1255 1255 + Blarglefish and that will search for both words in the forums ![]() Hope this helped, and have a great build season ![]() |
#11
Re: Rule 33 Robot
That's great to know!
But no worries...I just toss the suggestion out there for whoever keeps track of such things. Don't get me wrong -- this is a great resource! |
#12
Re: Rule 33 Robot
Seems simple enough. Thanks! |
#13
Re: Rule 33 Robot
A search for posts with Quote:
Regards, Mike |
#14
Re: Rule 33 Robot
Now for the rest of the story...
Said searches work best when "Show Results as Posts" is selected...otherwise, non-matching search results are returned on a per-thread basis (rather useless in threads with many posts). Maybe "Show Results as Posts" should be the default. |
#15
Re: Rule 33 Robot
Great communication skills coming from here... |
