Go to Post Often when discussing GP, the P half gets forgotten. - Taylor [more]
Unread 11-02-2011, 08:37
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: JVN Build Tip: Mechanism Loading
Originally Posted by dtengineering View Post
I want a video of the hot-dog roast taking place over the drive train at the end of the day!
I wonder if anyone has actually smoked a CIM... maybe they ARE indestructible in an FRC context.
Jason
Yes, 190 has. I do not remember the year, 2004 maybe. They did a mecanum drive and were overheating the CIMS big time. The robot rule that says "thow shalt not modify motor housings" belongs to 190 because they cut a window in the CIM housing and had small muffin fans on the other side/end pulling air through the windings. a really neat solution, actuallly.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 11-02-2011, 10:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Great post John; it should add a bit for knowledge to many varying levels of experience.
For our lift, I've done some math. We too will be using some surgical tubing to aid in the lift. We're using a 5/8" thick 2"/turn threaded rod at 50% of its critical speed -- we can increase that if we decrease its load. The hope is that we can use only 1 RS-775 to power it, yet we may still add a second one just to be on the safe side if we have weight to spare.
The surgical tubing serves a second purpose too, however. At the top and the bottom of the rod's range of movement, we've lathed off the threads in order to prevent the nut from getting ripped apart should the programmer's 3 safety pieces fail. At the bottom the tubing will combine with springs to lift it out of the bottom dead zone, thereby enabling us to continue scoring even sensors/code fail.
(Yea I know, threaded rod is heavy -- but we 'got a guy' who knows what he's doing with it, so I'd rather error on the heavy-but-quality side than try our multiple failed winch ideas again...)
GitHub
Unread 11-02-2011, 11:16
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Originally Posted by ThirteenOfTwo View Post
We learned passive assistance in VEX, specifically last year when we wanted to design a 254-esque arm to fling the game objects without any pneumatics. We actually gave our basket "negative weight". Footballs flew. Since then, passive assistance on every arm we've done, including on the VEX robot that made it onto JVN's blog. It's that useful.
Most of our VEX robots this year have passive assistance on their arms. The rack/pinion on a slider is great, the ability to "up gear" to move the arms faster is a must. The latex tubing makes this possible since there is less weight for the motor to move.
Nice post John, is this the famous "Subsystem 0" we keep hearing about on your blog?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 11-02-2011, 11:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Related question:
Does anyone have a stress-strain curve for surgical tubing? Anecdotal evidence suggests that it's possible to exit the linear-elastic region under FRC conditions. While it's generally not that big of a deal, given how FIRST teams use surgical tubing, I'm still curious.
Unread 11-02-2011, 12:03
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by Lil' Lavery View Post
Related question:
Calculator here: http://www.primelineindustries.com/tools.html
Results and explanation here: http://www.chiefdelphi.com/forums/sh...16&postcount=9
Art Dutra IV
世上无难事,只怕有心人.
