Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 11-02-2011, 08:38
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Spikes and CIM?
We were trying to use a spike to control a CIM on an old robot we're repairing. We blew a couple of fuses and talked to some mentors until finally someone said to try a Vic. The Vic worked, but does anyone know if we're able to use a Spike to control a CIM? The PD board was putting out 30 amps, and the Spike had a 20 amp fuse, is that the problem, or are they physically incompatible? Thanks!
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 11-02-2011, 08:46
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: Spikes and CIM?
Yes, that would be the problem. I've seen CIM motors draw about 40 amps. The Spike is limited to 20 amps, and (as you saw) the fuse will just continue to burn out.
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 11-02-2011, 08:57
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Spikes and CIM?
To answer your question: RTM. More specifically the wiring schematic. It will clearly show that controlling a CIM with a spike is verbotten.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 11-02-2011, 08:58
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Spikes and CIM?
The CIM draws vastly more current than the spike can handle. Spike is verboten.
Ed Barker
Unread 11-02-2011, 09:11
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Spikes and CIM?
Regardless of the rules (it sounds like you're trying to repair on old robot that won't be used in competition), a very important factor to keep in mind when pairing motors and motor drives is that, for a short period of time, DC brush motors will always draw stall current when starting from zero speed. Brushless motors can also draw high currents depending on the drive design.
The CIM's stall current when driven with a perfect 12V battery, wiring and motor drive is over 100A. A Spike cannot tolerate those 100A peak currents. Hence the 20A fuse/breaker that is often used on the Spike and why you keep tripping that overcurrent protection device.
Spikes and CIMs don't play nice which is why the rules generally (always?) do not allow that combination. Spikes will work well with most smaller motors, though. You'll just need to learn how to interpret the datasheets for the motors and Spike and select appropriate breakers and fuses.
Russ
Unread 11-02-2011, 09:16
Re: Spikes and CIM?
Guys,
A spike is only designed to handle 20 amps max. That is the rating on the contacts in each internal relay. When used with the compressor, you can change the fuse to a 20 breaker as the compressor start current exceeds 20 amps for a very short time.
A CIM motor on the other hand, has a stall current of 133 amps. That is the current it draws every time you apply current to it and it is not moving or everytime you are in a full throttle push with another robot and going nowhere. It will draw that current even if you put a 20 amp circuit breaker in place. Breakers do not limit current.
For FRC robots:
<R48>
A. Each CIM motor and Fisher-Price motor must be connected to one and only one approved speed controller. These motors must not be connected to relay modules.
Unread 11-02-2011, 15:53
Re: Spikes and CIM?
Just to be clear, that is the current it draws at 100% PWM with a 12volt supply when the motor is not moving.
Unread 11-02-2011, 16:18
Re: Spikes and CIM?
That would be what it draws if connected to a Spike and turned on.
Unread 11-02-2011, 16:40
Re: Spikes and CIM?
Sure enough :-)
