Go to Post But no matter how you place, the thing to watch for is the character change in the team members. The trophies are only important for a few hours. The character that is built will last a lifetime. - BrothersKeepers [more]
Unread 10-02-2011, 18:33
MathFreak's Avatar
MathFreak MathFreak is offline
Team Leader/Electrical
AKA: Hikari Iwasaki
FRC #5701 (Indigo Ninjas)
Team Role: Electrical
MathFreak is on a distinguished road
Line Sensor
Today we were trying to get the line sensor work, and it didn't look like it's working.
The line sensor shows these:
Green
Yellow
Yellow and Red
We said Green is detecting black, and for others we said it's not.
What we were supposed to get was to know if the line sensor works on the carpet. So we tried on the carpet, and it shows Green, Yellow, and Yellow and Red when we were trying on the same carpet.
We gave up, and I didn't get why it was like that.
Why was it like that?
Thanks
Hikari Iwasaki
2nd Grade student at Senior High school at Otsuka,University of Tsukuba
2014 Team5701 Team leader
2011 Team 296 Youngest team member
Team 5701 Indigo Ninjas
Website
Facebook
Twitter
Blog (in Japanese)
Unread 10-02-2011, 18:39
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Line Sensor
Its a digital input, hook up the brown to the negative and the blue to the positive, the black is normally closed and the white is normally open. Hack a pwm cable so that the black and white line up (read: soldering iron).
Have Fun
Unread 10-02-2011, 18:41
MathFreak's Avatar
AKA: Hikari Iwasaki
Re: Line Sensor
Have Fun
We got all of them, but we don't get why it shows all of the 3 sign (Green, Yellow, Yellow and Orange)....
Hikari Iwasaki
Website
Facebook
Twitter
Blog (in Japanese)
Unread 10-02-2011, 22:32
Re: Line Sensor
I hope nobody follows this advice. It's completely wrong.
Brown is the positive supply to the sensor, and needs to come from the red terminal of a 20 Amp circuit on the Power Distribution board (or from an output on the solenoid breakout if you want to use 24 volts instead). Blue is the power return (ground), and should come from the adjacent black terminal on the Power Distribution board.
Either black or white can be connected to the SIGnal pin of a Digital Input on the Digital Sidecar. The LabVIEW autonomous line-following sample code expects the white wire.
Unread 10-02-2011, 22:41
MathFreak's Avatar
AKA: Hikari Iwasaki
Re: Line Sensor
Blue is negative and Brown is positive, that's what a site on the internet was saying....
Hikari Iwasaki
Website
Facebook
Twitter
Blog (in Japanese)
Unread 11-02-2011, 10:31
1 * 4 != 14
Re: Line Sensor
We've been using Blue as negative and brown as positive and nothing has broken by us doing it.
Unread 11-02-2011, 10:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Line Sensor
Which is exactly the setup Alan described and is the opposite of what you originally posted.
Unread 11-02-2011, 11:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Line Sensor
I agree.
Robototes2412, please remove/correct your post.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-02-2011, 12:31
pfreivald's Avatar
AKA: Patrick Freivald
Re: Line Sensor
So in this setup, what is done with the black wires? Just connect them (a) to nothing or (b) to each other?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 11-02-2011, 12:33
RyanN's Avatar
RyanN
Re: Line Sensor
Neuter them. (Cut them off).
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 11-02-2011, 12:39
pfreivald's Avatar
Re: Line Sensor
That's what I thought. The kids managed to tear out several wires yesterday, and I wanted to be sure how to re-wire them properly (and am limited on time before build).
I won't GIVE them the answer, but I wanted to be sure what the answer IS so that I can check their work and make 'suggestions'...
Team 1551
I write books, too!
Unread 13-02-2011, 10:38
SudoSammich SudoSammich is offline
A pretty big deal...
AKA: Corey
FRC #0514 (Entropy)
SudoSammich is an unknown quantity at this point
Re: Line Sensor
Okay, there seem to be two points to this if I'm correct, the wiring and what those $@#$@#$@#$@# outputs mean.
Wiring: Blue is power and Brown is ground. They must be plugged into the power distribution block to receive the voltage they need (there may be another way, but this is what we found online, tried, and it worked). The black and white wires are "Light Output" and "Dark Output". You only need one of these for the sensor to really work. The light output makes the sensor read true when it's over light, while the dark does the same when the signal drops below the threshold. As such, you actually only need to run the white OR black wire on a pwm with only the signal wire to get the output you want on the Digital Sidecar.
As for the lights telling you what output you're getting, they're relatively simple if you read the paper that came with the sensors. Green means the sensor is A. receiving power and B. not giving output. If it's over the line, it shouldn't be showing green, since the output is energized. At the same time, your yellow light should turn on. The yellow light means the sensor is reading true, so it should toggle along with the green. The orange light is a little more confusing. When it is on, it means the sensor is receiving at least 2.5x the required signal strength to give a true output. What this really means is that the sensor is more certain that what it is seeing is the correct thing, not just background noise. This should only light up a a certain range from the target, and it's not actually necessary for tracking the line.
Hope this helps!
Unread 13-02-2011, 10:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Line Sensor
NO! This is backwards! Alan's post has the correct wiring description.
Unread 13-02-2011, 10:51
Re: Line Sensor
That works, until it doesn't work.
See the bottom of Page2 and the top of Page3 of this document.
