Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Unread 11-02-2011, 11:21
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: How should we wire the photoswitchs?
Originally Posted by Hugh Meyer View Post
Kent,
You may want to consider powering it with 24 volts. One of the updates makes it legal by connecting the sensors to a solenoid output on the cRio and powering that module from the 24 volts from the PDB.
-Hugh
Although it's hard to determine if you can only power one Line sensor per Solenoid output. (We'd like to power all three from one output)
Since you can only power ONE soelenoid breakout with 24V, you may find yourself running out of solenoid outputs...
eg: 3 double acting solenoids will consume 6 outputs, leaving only two to power the three line sensors.
Question: How does the load of one Line Sensor compare with the load of one Solenoid?
Phil Malone
http://www.GEARSinc.org
