Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 11-02-2011, 08:11
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Minibot wheel slip
hi everyone. so after much redesigning, my minibot is nearly finished, i just need a locking mechanism, which is being worked on. so i was testing my minibot on the pole, keeping it on with zipties. it certainly has enough grip on the pole, but even so, the single drive wheel still slips, and the bot does not climb. is there some kind of modification i could do to the wheel/tire to increase traction? someone suggested i use lighter fluid to irritate the rubber and give it a little more traction, but i want to know what you guys think. any suggestions will be appreciated.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 11-02-2011, 08:35
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Minibot wheel slip
We're still getting some slippage (the minibot falls down the pole a little but keeps going) with 2 motors and 4 wheels and enough magnets to almost pull the pole out of the base (exaggeration, but you get what I mean). It's the wheels itself, and that is definitely on our radar.
As for suggestions, try putting two motors on it, more torque > more pushing power, if you can afford the weight/space. As for wheel modifications, I don't know anything for sure.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 11-02-2011, 08:40
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Try grinding the rubber to match the diameter of the pole. We found spinning it up on a lathe and using a dremel tool with a grinding wheel spinning opposite the wheel rotation works well, followed by using some 80 grit sandpaper to "adjust" the diameter.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 11-02-2011, 09:31
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
we actually just turned the tires inside out, and it matches the diameter. even with that and the fact that the wheel it right up against the pole, it still slips
Unread 11-02-2011, 09:33
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
im using one motor, and it has more than enough power. that's not my issue though. plus, i do not believe i can afford the space/weight.
i jus want to get the tires to have more traction
Unread 11-02-2011, 10:17
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
try wrapping rubber bands or surgical tubing around the wheels
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 11-02-2011, 10:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Move the battery away from the pole, slightly -- definitely do not put it right up against the pole. Put it level with or just slightly below the traction wheel in terms of vertical positioning. This change in center of mass creates a pivot point at the traction wheel. That pivot point will then create a moment at whatever contact is on the opposite side of the pole. If that contact point is higher than the traction wheel, it then acts as a pivot to create a moment on the traction wheel itself, thereby increasing the wheel's force to the pole (i.e. traction). Note that this will also increase the friction on 'zip ties' or whatever other locking mechanism you use, so design accordingly.
The very first prototype one of my students made was exactly like this, yet didn't lose traction. It was a 4-4.5 second bot due to the excess friction though.
GitHub
Unread 11-02-2011, 10:58
itrvd itrvd is offline
FTC #0128 (S*M*A*S*H)
Team Role: Electrical
itrvd is an unknown quantity at this point
Wow... I thought that we weren't doing all that well but now I feel differently. I have a video if you guys want to see it and make your minibots similar!
Unread 11-02-2011, 10:59
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
We noticed that the wheels picked up dust from the shop real easy. A wipe down with a moist paper towel before each run took care of the issue for us. We couldn't break 3 seconds without that little bit of maintenance each time.
Is anyone planning to wipe down the poles to make sure they are clean before their matches? I wonder if field reset will do this automatically as part of their routine. I imagine the poles could get a bit dirty after several minibots make their way up and down.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 11-02-2011, 11:07
Generator of Entropy
FRC #2973 (The Mad Rockers)
Hmmmmmmmm... Slippage occurs because the tangential force due to the applied torque exceeds the friction force, which is normal force times coefficient of friction. Adding a second motor doubles the tangential torque force, so if Ft > N(mu) for slippage, I would bet that 2*Ft > N(mu) as well.
Your choices are 1) increase the normal force and 2) increase the coefficient of friction
Unread 11-02-2011, 12:08
Zuelu562's Avatar
AKA: Jake Janssens
Check: you can increase the normal force with a very ingenuous way using the motors themselves...
sandpaper anyone
Team Resume
Volunteer Resume:
Unread 11-02-2011, 12:32
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
i already got my positioning figured out, so that's solved. my battery does not touch the pole. only the pvc guide and drive wheel do. the pvc is getting good grip, and the wheel has plenty of power and torque thanks to the gear ratio. even still, the wheel slips against the metal pole.
would irritating the rubber tires with some kind of fluid to give it some traction? i think my tires are the major factor in my problem
Unread 11-02-2011, 13:00
Chris is me's Avatar
AKA: Pinecone
How much of your normal force is going to that PVC guide instead of your wheel?
Unread 11-02-2011, 13:32
JesseK's Avatar
FRC #1885 (ILITE)
i already got my positioning figured out, so that's solved. my battery does not touch the pole. only the pvc guide and drive wheel do. the pvc is getting good grip...
If avoidable, you wouldn't want any pvc 'grip' at all. Excessive drag forces could attribute to some of the wheel slip. Perhaps you could figure out a way to make the pvc guides into rollers so there's less resistance.
The placement tweaking of the battery is a manipulation of the c.g. in order to acquire more normal force to the pole for your traction wheel. It works in the same manner that the mechanism at 1:27 in this video works for creating normal force to the pole. The c.g. relative to the pole was out from and below the driving wheel, while the idler wheel was above it. If you've already put it where you can based upon the sizing constraints, then that's about all you can do for that.
GitHub
Unread 11-02-2011, 14:49
AKA: Dana P. Henry
[quote=would irritating the rubber tires with some kind of fluid to give it some traction? i think my tires are the major factor in my problem[/QUOTE]
Are you using the stock FTC 3 or 4 inch wheel?
All we did was to radius them to match the radius of the pole (see above post) and use the sand paper trick and we are getting 2.5 second climb rates consistently with 2 motors powering one wheel and magnets holding the whole thing on the pole.
Before using any type of fluid, I would check the legality of such use in the Manual first.
