Go to Post communication at its best = quick, brief, clear - JaneYoung [more]
Unread 11-02-2011, 13:49
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Re: Issue with autonomous mode and some newbie questions
Originally Posted by Robby Unruh View Post
Your problem lies here:
for(int i =0; i < 10; i=+1){
    getWatchdog().feed();
    robotdrive.drive(1,0);
    Timer.delay(3);
You're using a timer delay in a loop. That means that everytime the loop is called (which is two, for whatever reason) you will have a 3 second delay. Plus, since you're wanting to drive for a set amount of time in autonomous, why not use the nifty Timer class?
Timer timer = new Timer(); // you should put this in your constructor.
public void autonomous() {
    while(isAutonomous()) {
        timer.start();
        while(timer.get() < 3) { // while the timer is < 3, drive forward.
            robotDrive.drive(1,0);
            timer.stop(); // stop the timer after 3 seconds
        robotDrive.drive(0,0); // stop the robot from driving any further.
I thought the timer delay pauses the code. Since the motors weren't told to stop before the timer delay so it should continue straight for 3 seconds. And it should do it 10 times according the for loop.
I think the issue is that the watchdog is not being fed during the pause so the robot shuts down. Could this be the issue and how could it be fixed?
