Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-02-2011, 15:35
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Scouting Power System
Seeing some of the issues we have had in the past, we are looking into working up a power supply system for our scouting setup this year.
I know a few teams from that thread have worked with UPS's or other things, could you provide details on your power setup?
Here are my thoughts for ours so far...
Power Draw
1 Linksys Switch
6 IBM Thinkpads
1 Dell Lattitude D600
If my numbers are right, we need ~1100Wh supply to run for 9 hours
I would prefer to stick with DC, so DC-DC converters from a Marine Battery or from military BB590 Batteries (Harris has easy access to these).
It seems like a lot of teams do DC-AC-DC which is just so terribly inefficent that I don't want to lug around that extra power
Anyone do anything like this? Ideas?
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 11-02-2011, 15:52
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
Re: Scouting Power System
When we need extra power we just take robot (or car) batteries and attach a power inverter. Yes is is rather inefficient but it is also simple. And you could stretch the power by using power saving settings on the laptop.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 11-02-2011, 16:23
foozie's Avatar
foozie foozie is offline
AKA: Matt Howard
FRC #1124 (The ÜberBots)
Team Role: Webmaster
foozie is an unknown quantity at this point
One of the reasons that the DC-AC-DC system is used is that the inverter and the rectifier-power-bricks for the laptops or whatever supply the system with a good level of regulation and signal-grooming. Take that away, and you may just fry a laptop or two. Be warned.
Unread 11-02-2011, 17:13
klmx30302's Avatar
AKA: Kevin McCarthy
um... didn't read the part about 7 laptops. So lets see 1100wh/12v= 91ish amp hrs so that's 2 normal car batteries now take into account 80% inverter efficiency 91/.8= 113.5ah now say the laptop power bricks efficiency is around 80% 113.5/.8=142.5ah that means you would probably need 3 fully charged car batteries hooked up in parallel to get the appropriate amount of power which at this point would be 142.5x12=1700wh.
Unless of course you already took this into account in which case you should be fine with 2 car batteries.
Our team motto...
Unread 11-02-2011, 19:15
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
My freshman year (Lunacy) we tried our UPS with our 7 laptops and a switch. The inverter couldn't handle any more than 3 laptops at a time, and the batteries instantly drained. It did NOT work for us at all. We evolved to essentially creating our own scantron. The best mix between paper and technology.
FRC Team 93 Alumni
[IMG] code is Off
