Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 11-02-2011, 16:06
Re: How to start programing mecanum wheel drive ?
The Y input to the Cartesian variety of the Mecanum Drive vi follows the standard HID joystick convention where negative means forward. If your joystick value is negative but your robot is going backwards, you probably need to change the MotorInverted inputs on your Open Drive vi in Begin.
If your joystick value goes positive when you press the joystick forward, the appropriate fix is to insert a Negate function between the joystick axis output and the mecanum drive Y input. It looks like (-x) in a right-pointing pale yellow triangle, and it can be found in the Numeric function palette.
