Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 10-02-2011, 19:59
Nerd_Skywalker's Avatar
Nerd_Skywalker Nerd_Skywalker is offline
Walker of Skies
FRC #1111
Team Role: Animator
Nerd_Skywalker is an unknown quantity at this point
Submission Registration Open!!
Hi all!
They have (finally) released the registration on the FIRST section of autodesk.com in the 3D Animation Tool Kit.
Go register now!
Re-dun-dant adj. 1. See redundant
Unread 10-02-2011, 22:32
lisasaurusrex lisasaurusrex is offline
FRC #0192
Team Role: Animator
lisasaurusrex is an unknown quantity at this point
Re: Submission Registration Open!!
Our team is having trouble registering. Whenever we try to enter our team name and number, an error displays that says "Incorrect team number". We're not exactly sure if it has to do with the team name matching with the team number, but we've tried tons of variations and none seem to work. Are there steps we have to take before registering??
Unread 11-02-2011, 08:59
George Nishimura's Avatar
George Nishimura George Nishimura is offline
Lurker
George Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud of
Out of curiosity, how long should we leave for uploading? Worst case scenario that is..
Unread 11-02-2011, 09:14
TomT_1517's Avatar
TomT_1517 TomT_1517 is offline
Animation Mentor
AKA: Tom Tosi
FRC #1517 (Lumberjacks)
TomT_1517 is an unknown quantity at this point
Registering worked fine for me and here's what I did. For the "Team Name" field, I first went to the usfirst.org site, found a regional that we are competing in this year, found the listing of our team name, and copy and pasted that into the "Team Name" field on the Autodesk form. I'm not sure if that makes any difference but just in case Autodesk gets their team names from a FIRST database, I wanted to make sure they matched exactly. Maybe that didn't matter and it would have worked anyway, I don't know. Hope that helps.
Unread 11-02-2011, 15:38
Jreed129's Avatar
Jreed129 Jreed129 is offline
animation mentor
AKA: Jeremy Reed
FRC #0103 (Cybersonics)
Jreed129 will become famous soon enough
Our team is also having the problem "Incorrect team number". The solution above has not worked.
Try to upload it the day before just to be safe uploads have taken anywhere form 10 mins to 2 hours it is just better to get it done sooner then later. the bigger problem you might run into is getting the right upload speed.
Unread 11-02-2011, 17:15
TomT_1517's Avatar
Animation Mentor
AKA: Tom Tosi
Do you know if this entry/upload mechanism appears different from what Autodesk has used in past years?
Team 1517 Lumberjacks participating in Granite State Regional and Festival de Robotique FRC a Montreal
Regional in 2012. Hope to see you all there!
Unread 11-02-2011, 18:38
FRC #0192
Team Role: Animator
We tried registering on Autodesk's site a couple times. Somehow, eventually we got the form to submit even though it still displayed the same error. Strange :-/
Unread 12-02-2011, 07:03
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Sorry if this is obvious, but did you try "0192" instead of "192"? Maybe they need 4 digits for all teams.
Unread 12-02-2011, 08:12
TomT_1517's Avatar
Animation Mentor
AKA: Tom Tosi
Very keen observation! Both teams in this thread that reported a problem have a team number with 3 digits. It will be interesting to see if that was the issue.
Unread 12-02-2011, 13:07
Jreed129's Avatar
animation mentor
AKA: Jeremy Reed
We did try this and it still did not work but if you enter the team number last and then click submit it seems to have worked
Unread 12-02-2011, 17:56
FRC #0192
Team Role: Animator
Yes, the 0 before the team number doesn't change anything (the error is still displayed) but somehow we were still able to submit our information.
Unread 12-02-2011, 18:59
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
I registered using 0847,
but I have not seen an email - isn't that's what is supposed to happen?
Have you guys got the email w/ instructions to upload?
- PHRED 847 mentor
Unread 13-02-2011, 16:31
FRC #0192
Team Role: Animator
Also, is there a limit to how many team members you can add? I've only been able to add five.
Unread 13-02-2011, 19:37
TomT_1517's Avatar
Animation Mentor
AKA: Tom Tosi
We could only add five as well.
Unread 14-02-2011, 19:38
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
Originally Posted by Nerd_Skywalker View Post
Hi all!
Go register now!
But it just crashes for us. Grrrrr.
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
