Go to Post Adult coaches are the "rock stars" of our program, and I know on Simbotics the kids really do look up to and aspire to be a great as these coaches. - Karthik [more]
Unread 11-02-2011, 17:29
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
Re: Smoking RS-550 motors
Al:
This is an forklift/elevator belt running off a 3" diameter timing belt pulley, so there is near continuous load, except for a small increase when the 2nd section of the elevator starts to lift.
The motor is out in the open with no obstruction to the air-in/smoke-out holes.
Ether - you are right. The lecture materials I remembered had alot of discussion about finding the peak power point, but also noted the manufacturers typically recommend a normal operating speed at some high percentage of the free speed, such as 80%.
The good news: we should be closer to that 80% before we are done. The bad news, operating at 40% may be too much for the RS-550s to handle, even for 2 seconds at a time.
-Jeff
