Re: Minibot microswitches?
I don't know what a "standard" microswitch is. If it is like the type that came in the KOP then the answer is yes.
can they me used with power wires or are they a data switch?
Check the datasheet for each switch to get definite answers about current and voltage handling. I was surprised to see how capable those little devils have become since I first used them more than 30 years ago. You may have to look around a bit to find female blade connectors for the terminals, too. Most automotive applications (the easiest to find) use a larger blade, I think.
Bill,
You are right on the spade connectors. You can easily find the .250" but the microswitch is .187" as I remember. |
My team as had a hard time finding switches for our minibot, but we think we have it all set with my understanding of the rules |
Yes, the KOP microswitches are listed in the catalog as "limit switches".
"MICRO SWITCH™ V5 and V7 Series basic switches are used for simple or precision on/off, end of limit, presence/absence, pressure, temperature and manual operator interface application needs. " Last edited by Al Skierkiewicz : 13-02-2011 at 16:43. |
#7
Whoops, definitely thinking of the wrong type of switch
We're using some very close to those on our minibots. |
#8
My team was thinking about putting a compression switch on our minibot so that when it came in contact with the pole it would compress and go up the pole, would a compression switch fall under limit switches or common household switches?
#9
wild war bots - If it's marketed as a "limit switch" or is readily identifiable as a limit switch, you won't have a problem. If it looks significantly different from those included in the KoP and isn't marketed as a "limit switch", then i would find something else to use.
#10
Whoops! looks like someone beat me to the answer...
Limit switches: Quote:
