Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Unread 10-02-2011, 17:03
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Lights for vision target
We (the team) are trying to get an LED light onto or near the camera, in order to illuminate the vision target: Some questions:
  • What brightness level should the light be to illuminate the target without washing out (right term?) the image?
  • How would we wire the light onto the robot?
Unread 10-02-2011, 20:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Lights for vision target
1. Not very bright at all would be plenty. Think small flashlight, not 747 landing lights. Try a Radio Shack yellow LED, as long as it's mounted right at the camera, the retro-reflective tape will live up to its name.
2. I suggest using a spike, but there are other legal methods. Using the Pneumatic Solenoid bumper is NOT a legal method. The Digital Sidecar might not have sufficient current available to drive even a small LED.
Unread 11-02-2011, 00:46
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
We're currently using four red LEDs around the camera lens, each at roughly 3 candela. It is subject to change, yet, depending on what the programmers decide they need, but my understanding is that it's working relatively well so far
Unread 11-02-2011, 16:50
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Using the Pneumatic Solenoid bumper IS a legal method as of update 8.
As others have said, don't use too bright a light, unless you want to blind your alliance drivers.
-- Marshal Horn
Unread 11-02-2011, 16:53
Er, what part of the Robot Manual dictates which methods can be used?
Also, can I get a measurement of how bright it should be?
Unread 11-02-2011, 16:57
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
That is incorrect.
<R42> that was changed in update 8 refers to Spike relay modules, not solenoid modules. <R60> still says exactly what can connect to solenoid modules:
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric
sensors, PN 42EF-D1MNAK-A2, only. No other devices shall be connected to these
outputs.
Kettering Motorsports
I assume you're talking about the modification to <R42> in team update 8? No where in the rules, FIRST documentation, or NI documentation is the solenoid breakout module or digital sourcing module referred to as a relay. I believe <R42> refers to a spike relay only and not the solenoid breakout, so it is not legal to hook a light up to the solenoid breakout.
Unread 11-02-2011, 17:03
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Thanks for correcting me!
It seemed reasonable to me to have a low-current light on an output where you can draw up to 3A. Re-reading R42, the intent is actually to allow multiple lights, or multiple solenoids, to be powered in parallel by a Spike relay.
-- Marshal Horn
Unread 11-02-2011, 17:35
Okay then, use a Spike relay to connect the LED to the robot.
Are there any other methods available?
Unread 11-02-2011, 17:46
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
If you're into making electronics, you can make a "custom circuit" and hook it up to a digital output.
-- Marshal Horn
Unread 11-02-2011, 17:49
Wicked,
Remember that the light will be too bright when you or your alliance cannot see the field with the light shining in their eyes.
Does not everyone know that the camera can be adjusted for varying light levels?
I think we'll stick with the Spike relay.
Last question: what specific brightness range should the light be in?
Unread 11-02-2011, 22:49
Someone pointed out to me the other day that the blue plastic housing associated with the Solenoid Breakout actually is prominently marked "RELAY". However, that's the only place I know of where that word is used for that module.
