Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 11-02-2011, 17:59
Spectare Spectare is offline
Team Hacker
AKA: Benjamin Pylko
FRC #3181 (Pittsford Panthers)
Spectare is an unknown quantity at this point
Question CANJaguar current mode
I am on the IgKnighters Team at McQuaid, I am trying to program some small BaneBot DC motors, but I cannot find a way to set the maximum current draw of a CANJaguar so as to not burn out the motor. I can find voltage, but not current. I have tried changeControlMode(CANJaguar.ControlMode.kCurrent), but I am at a loss as for what to do after that. Can Anyone help with this? Thanks in advance!
Unread 11-02-2011, 23:02
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: CANJaguar current mode
if you use the current control mode then what you set with the set method is the current outputted to the motor.
for example
jag.set(10);
Would set the jag to output ~10 amps.
also you can consider the getOutputCurrent() to return the current it is currently outputting
Unread 12-02-2011, 10:42
There is no built in way in the jaguar to limit current while using one of the closed loop control methods. However, Ether wrote a white paper called CAN Jaguar Speed or Current Control with Current Limit or Thermal Cutoff which shows an algorithm for doing this on the cRIO.
Unread 14-02-2011, 16:05
Team Hacker
AKA: Benjamin Pylko
Thanks, I actually found out that a CANJaguar will not supply more current(or voltage) than is supported by the motor, so . But thanks anyway for the reply.
