Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 11-02-2011, 17:19
3359prgsquad's Avatar
3359prgsquad 3359prgsquad is offline
FRC #3359
3359prgsquad is an unknown quantity at this point
Tank drive problems
My team and I are having a problem with our tank drive program. We are use logitect playstation looking controllers. The two axis were set as 2(y-axis) and axis 4. For some strange reason it stop working. Some is preventing us from turning. I noticed that one stick on the controller is makling the robot to move foward. With tank drive i thought that the just moving one joystick will make only one certain side move.... CAN ANY ANYONE HELP ? ? ?
Unread 11-02-2011, 17:33
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
Re: Tank drive problems
Make sure that the motors are controlled by different axis values. Make sure that you havnt wired the same value. If you upload a VI I will be glad to review it.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 11-02-2011, 18:22
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
your description sounds like arcade drive. verify that you have it set to tank and not arcade drive.
Unread 11-02-2011, 22:51
Might one side not be working at all? A skid-steer robot will generally go straight if only one side is powered.
