Go to Post We want to win, but we would prefer to do so with a great partner team, not just a great partner robot. - Zach Purser [more]
Unread 11-02-2011, 22:12
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Arm angle finder
Originally Posted by theprgramerdude View Post
This.
If you can't afford PWM, you're beyond helping.
Well, it COULD be they ran out of slots on the IO Board.
Although, I believe you are allowed to use a second one...
Unread 11-02-2011, 22:40
Guys, this question is from the team that ran the "Brother's Keeper" automode back in 2007. That automode is one of the most complex ones to ever be attempted to date, and only one team ever managed to run it successfully. Something is going wrong if they're having trouble with both a gyro and a pot.
First question: What code are you using for pot/gyro reading?
Second question: What is the reason for the lack of PWM cables? Are you simply using CAN?
If you need a good temporary solution, I'd go with a gear tooth sensor of some form. (You could do it with a magnetic one, or build a beam-break sensor, or something much crazier.) You know which direction the arm is supposed to be moving, by motor direction command or by gravity in the absence of that command. You set the count to a known value at the start of the match, so you have a reference point. Now you count teeth. Each tooth is some number of degrees on the sprocket/gear/whatever you're measuring with. Now you know how many degrees and which direction.
It's not quite as good as a pot, but it should do the trick.
