Go to Post We may not have any Paris Hiltons around here (though I've heard Paul Copioli is a great kisser) - AndyB [more]
Unread 11-02-2011, 19:29
FREEZERMAN910's Avatar
FREEZERMAN910 FREEZERMAN910 is offline
FRC #0910
FREEZERMAN910 is an unknown quantity at this point
Arm angle finder
We need a way to find the angle of our arm during a match, but we can't use a gyro or a potentiometer due to either programming error or lack of pwm cables. Please help we need to do this without using said things.
Unread 11-02-2011, 19:38
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Arm angle finder
i am not sure if you can. my only guess would be to use the camera to find height (by what it is seeing) and somehow deriving an angle from that.
otherwise, your choices are:
potentiometer
encoder (analog or digital)
gyro
magnet sensor (technically an encoder)
Unread 11-02-2011, 19:39
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You could always guess... based on how long you have driven the arm... but it won't be accurate.
Why can't you use a pot? There really isn't much programming error...
Also, another option is to use limit switches.
Unread 11-02-2011, 19:55
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
go and buy about 20 feet worth of triple PWM, and 10 ft of double
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 11-02-2011, 22:10
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
This.
If you can't afford PWM, you're beyond helping.
Attending: MN Duluth Regional
Unread 11-02-2011, 22:12
AKA: Matt B
FRC #1771 (1771)
Originally Posted by theprgramerdude View Post
This.
Well, it COULD be they ran out of slots on the IO Board.
Although, I believe you are allowed to use a second one...
Unread 11-02-2011, 22:40
Guys, this question is from the team that ran the "Brother's Keeper" automode back in 2007. That automode is one of the most complex ones to ever be attempted to date, and only one team ever managed to run it successfully. Something is going wrong if they're having trouble with both a gyro and a pot.
First question: What code are you using for pot/gyro reading?
Second question: What is the reason for the lack of PWM cables? Are you simply using CAN?
If you need a good temporary solution, I'd go with a gear tooth sensor of some form. (You could do it with a magnetic one, or build a beam-break sensor, or something much crazier.) You know which direction the arm is supposed to be moving, by motor direction command or by gravity in the absence of that command. You set the count to a known value at the start of the match, so you have a reference point. Now you count teeth. Each tooth is some number of degrees on the sprocket/gear/whatever you're measuring with. Now you know how many degrees and which direction.
It's not quite as good as a pot, but it should do the trick.
