Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
Unread 11-02-2011, 21:49
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Logitech Attack 3
So, I was wondering how if the joystick is the only axis on the Logitech attack 3. Also, would it be possible to hook a motor up to a button through the programming.
Unread 11-02-2011, 21:50
Lead Programmer
AKA: Josh
Re: Logitech Attack 3
It will control the robot's arm/claw and the minibot deployment.
Unread 11-02-2011, 22:17
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Before I answer your question, I'd like to correct you, the throttle control on the bottom middle is also an axis if you must have axis control over something (although I don't recommend it).
If you want a button to move a motor at a set speed when pressed, use something like this.
If you want a button to move a motor at a set speed when pressed but does not reset, this will do the trick.
What the first one does is you get the button of the joystick you want to use, and when true, selects the .5 motor value and sets the "reach motor" to run at .5 speed until the person lets go of the button.
The second one, however, just sets the motor to run at .5 speed whenever one button is pressed, and turns it off with another button.
The reason I chose these two examples are to show the multiple ways you can use the buttons to move motors. (using case statements and using selects)
Unread 12-02-2011, 19:15
lonski lonski is offline
FRC #2486
lonski is an unknown quantity at this point
Hello does annyone know how to wire the throttle (axis 3) with labview for the logitech attack 3 controolers
Unread 12-02-2011, 19:45
PatrickS's Avatar
PatrickS PatrickS is offline
I get my code from /dev/null
FRC #1742 (Shockwave)
PatrickS is an unknown quantity at this point
The same way would wire axis 1 (x) or axis 2(y). Just expand the unbundle by name array.
