Go to Post Don't tell the rookies to "not touch the robot", show them how to work safely. - Andy Baker [more]
Unread 11-02-2011, 22:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Help with servos
You can connect the joystick output to two servos, and Negate one of them.
You could also use joystick buttons:
Use a logic switch (from the Comparison palette) and connect the switch (center input) to one of the buttons. True would set the value if you press the button, False would set the value if you don't press the button. Once again, you can connect it to both servos and Negate one. I recommend the not-pressed state to be closed if you do this, since claws are closed most of the time.
Kettering Motorsports
