Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 11-02-2011, 06:58
mitchftw903 mitchftw903 is offline
mitchftw903 is an unknown quantity at this point
WindRiver C++ Installation CD
We just got done getting the main code done for our robot done. Now that a lot of the work is done I wanted to see about implementing all our code on C++. Only problem is my team can no longer find the installation CD for windriver c++. I was wondering if anyone could provide me with an .ISO image I could download.
Unread 11-02-2011, 12:36
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: WindRiver C++ Installation CD
Uploading to Dropbox.
Unread 11-02-2011, 18:24
Thank you so much!
Unread 11-02-2011, 19:14
Emily Horsman
It's a CDR because I made the image on OS X, nonetheless:
http://dl.dropbox.com/u/96856/OPTIAR...20AD-5680H.cdr
This link will be gone at 10PM EST Feb 12th.
Unread 11-02-2011, 22:00
I am almost done, have 21 minutes left.
Unread 11-02-2011, 22:27
Are you sure about the file integrity of that image?
Unread 11-02-2011, 22:29
Emily Horsman
Unfortunately not.
Unread 11-02-2011, 22:32
I am on a Windows box so I went ahead and renamed it to a .ISO. I then attempted to burn it with Nero and I am getting block size errors. Hmm I will keep trying.
Thank you for your effort! Most people would have been like "meh".
Edit: Apparently I an find the original block size with ISOBuster. Will tell you if I am successful.
Unread 11-02-2011, 22:35
Emily Horsman
Could you mount it as a drive instead?
Unread 11-02-2011, 22:48
Yea that is my second plan if this doesn't work. I am trying to extract the content to a local file and run the installer that way. If that doesn't work I will mount it.
Will I need a key for this installation?
Unread 11-02-2011, 22:56
Emily Horsman
Installation key file is on the CD, specify during installation. Remember that WindRiver is only donating licenses for team usage.
Unread 11-02-2011, 23:00
I wish I have a NI FPGA at home to play with. Yea but the installation isn't going any better even mounted :/
Thanks for trying. Cheers.
Unread 12-02-2011, 01:47
Now it says the Product Activation file is invalid :/
Unread 12-02-2011, 14:12
Emily Horsman
Someday :'(
I was under the assumption we had at least twenty-five licenses of WindRiver for team usage this year - was I maybe incorrect?
