Go to Post MR. KAMEN! TEAR DOWN THIS WALL! - Briansmithtown [more]
Unread 11-02-2011, 23:35
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Exclamation Solenoids and <R74>
<R74>: Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve. Plumbing the outputs from multiple valves together into the same input on a pneumatic cylinder is prohibited.
How would everyone translate this rule? It obviously means that we can't connect the outputs of more than one solenoid to a cyllinder, but what about connecting the input of a second solenoid to the outputs of the first solenoid, to control whether or not air can come out of the first solenoid? Would that be legal, or does one solenoid and one solenoid alone have to control the movement of the piston?
Unread 11-02-2011, 23:39
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Solenoids and <R74>
I'll ask a potentially silly question: Why wouldn't you handle a control mechanism like that in code? Off the top of my head, I can't imagine a cascade of solenoid valves that couldn't have their functionality replicated in control code for several independently plumbed solenoids.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 11-02-2011, 23:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I read that as one outputs worth of air goes into each piston. Turning two solenoids into a center-locking valve would still be allowed. However, I am not the GDC.
Unread 12-02-2011, 00:08
AKA: Ty
Ask a silly question, get a silly answer. We are trying to stop the cyllinders mid-stroke, which has turned out to be harder than we originally thought. The cyllinders can be stopped if you stop the exhaust from escaping, with a second solenoid. Otherwise, it's very difficult to stop them mid-stroke.
Unread 12-02-2011, 00:14
FRC #6357
Fair enough. That makes a lot of sense. I also think your multiple valve cascade passes muster under the rules. I believe the real concern with having multiple valves on the same cylinder is that GDC wants to limit the flow rate. Your set up wouldn't violate that.
As a thought, have you considered a double acting valve? That would let you apply pressure to both sides, which should also lock the cylinder, and cut down one solenoid valve.
Just keep in mind that in either case you won't be "locked" in position. Air does compress, after all.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 12-02-2011, 00:15
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
u cant stop them mid stroke they will always extende if u put pressure to both sides ther is more surfuce area to extend then retract the rod blocks some of the retraction area
http://docs.engineeringtoolbox.com/d...c-cylinder.png
if u look at that picture u can see why there is less surfuce area to retract
yes u can plug the exhaust and it would stop somewhat in the middle
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 12-02-2011, 00:21
AKA: Ty
Yes, the compressability of air does make it a bit problematic. It does stop, as long as it's sitting stationary in our shop, with no forces or accelerations acting on it, but in competition, who knows if that will still happen!
Unread 12-02-2011, 00:22
FRC #6357
Duly noted.
So, I guess you really do need two solenoids then. I stand corrected.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 12-02-2011, 00:24
You can stop them mid-stroke. It's been done. It's been done in FRC.
If you put the same pressure on both sides, the piston may move...
...Provided that the displaced air has somewhere to go. If that air has nowhere to go, then the piston's motion will stop as soon as the force on each side is equal. Motion will resume as soon as the air has somewhere to go again. By placing a single solenoid on the exhaust of a double solenoid, it is perfectly possible to gain control over where the piston stops.
Unread 12-02-2011, 00:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
http://forums.usfirst.org/showthread.php?t=16848
Sorry, but your question appears to have been answered...
Unread 12-02-2011, 00:45
FRC #6357
Seems that one double acting valve may be the best you can do...
Using two secondary regulators may resolve the force balancing issue that's been pointed out, though that would take a lot of tweaking.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 12-02-2011, 00:35
cmwilson13's Avatar
What i said is still correct if u put the same presure to both sides IT WILL EXTENED. If u plug the exaust then the cylinder compress the air in the side wth less surfuce area untill the forces equilize
Unread 12-02-2011, 01:25
Chris is me's Avatar
AKA: Pinecone
that equalization may be before it's fully extended. Potentially a particular, predictable amount before.
Unread 12-02-2011, 02:45
AKA: Ty
That brings us back to the original problem though, because you can't have more than one solenoid controlling the inputs of one piston, so you can't have a "stop solenoid", whether it's before the primary solenoid, in the feeder line, or after the primary solenoid, in the exhaust line. It's still illegal, according to <R74>
Unread 12-02-2011, 07:56
wilsonmw04's Avatar
Coach
so the way we have gotten around the lack of center locking solenoids in the past is now illegal. I wonder why they axed this after many years of it's use?
