Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
Unread 12-02-2011, 00:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
12v/24v Festo Solenoids
Hello all,
So the Festo valve we got in our kit is the 24v one and we rigged up to solenoid break-out and it works perfectly.
We needed a 2nd solenoid so we ordered off andymark, and got it today after assuming it was the same thing wiring it up to the breakout i noticed it was running a bit hot. Then realized it was a 12v solenoid getting 24vs....
So my question can the 12v Solenoid take the 24v?
Or do we have to use an spike relay? <-- Which i don't really want to do more wires etc.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 12-02-2011, 00:40
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: 12v/24v Festo Solenoids
I don't think that you should power the 12 volt coil with 24 volts, however you could add a second solenoid module and breakout to which you could supply 12 volts or you could use spikes.
Unread 12-02-2011, 00:46
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
im surprised you're having a problem, we used to do it all the time. there must be a problem we just got lucky not to have. in slot 7 put another pnuematics module with 12 volt wiring and wire that one there.. just remember to change slots in your programming for that solonoid. best of luck
2057
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 12-02-2011, 01:11
Electrical Engineer
Rookie Year: 1995
Powering 12V devices with 24V is a practice I would avoid unless the manufacturer's spec sheet says it is OK. Power dissapation goes up as a square of the voltage.
FIRST just posted 12V and mixed (12 and 24V) power distribution diagrams on the KOP website. I would stick to their wiring recommendations.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 12-02-2011, 01:22
Mk.32's Avatar
AKA: Mark
Thanks for the input everyone.
To add an pnuematics module to slot 7, can we do it from the KOP or do we need to order anything more?
Unread 12-02-2011, 07:50
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
You'll need a second Digital Sourcing Module (NI #9472). Veteran Teams will probably have 2 of these accumulated from previous years while 2011 Rookie Teams will only have recieved 1 this year.
Might be easier to get a second valve @ 12VDC or 24VDC and use the existing module.
Don
