Go to Post My sister's husband told me when I was just a wee one, "momentum will take you where traction will not." - Joe Johnson [more]
Unread 02-12-2011, 02:48 AM
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Re: WPILib Mecanum Function Not Strafing Properly
Originally Posted by Alan Anderson View Post
If you had control of the front motor on one side swapped with the rear motor on that side, you'd probably get the results you're seeing. Start by verifying that the motors you're telling the code about are actually on the corners you're telling it they're on.
That sounds promising now that you mention it. Unfortunately, I'm not working on the robot for a bit, so I'll have to look into that and get back to you guys in a couple days.
