Go to Post darn design trade-offs! the game design committee does this to us every year! - KenWittlief [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 05-11-2002, 14:56
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Question Dual Moniters - Anyone done it or has knowledge about it?
Alright, so a few days ago, my cisco teacher was throwing old computers away. Among one of the things I scavenged from these were near-useless generic video cards from '95 or '96. I said to myself, "you know what? In that ol' server machine of yours, you've got a top-of-the-line pci card from a few years ago. Why don't you put the generic sheizer '96 card there and get a dual display system going on?"
In my main system, I now have a GeForce256 (which, through the powers of a soldering iron, is now a blazin'-fast-for-3dmax-and-other-CAD-programs Quadro card) and a oldskewl once-top-of-the-line Diamond Viper PCI card (windows recognizes it as a TNT, which I cannot confirm or deny because I've since lost the origional box/information). Here's the problem, though: when the PC boots up, the Quadro works, but the Viper doesn't. In Windows (XP Pro, if it helps), Device Manager has that little yellow ! next to it. It says, "This device cannot start. (Code 10)"
So at this point I have a AGP Quadro card that works fine and a PCI TNT card in my system. The TNT didn't work at this point, so I go and install the latest nVidia Detonator drivers on the card(Diamond has since gone under as a video-card manufactuer, and Detonator supposedly supports TNT). Unfortionately, this didn't fix the problem either. I still have that little ! in Device Manager that says the device cannot start.
So, off I go to ChiefDelphi. Has anybody ever put in two video cards into their computer to get a dual-display system going? Were you successful? Did you use any special program? Do you have any tips/suggestions/etc that you've seen online?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 05-11-2002, 15:55
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
I have 2 in my system right now, but I don't have the 2 monitors hooked up. I am pretty sure, all you need to do is to put them both in, and then in the display properties to set them up as the primary, and the secondary.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 05-11-2002, 16:06
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
I have a monitor attached to my laptop, and my desktop stretches across the monitor & laptop lcd.
I've also used a computer for the score system at the past CDI's that had 3-4 monitors attached. We needed a separate video card for each monitor.
I think you can do it in 95,98,ME,and XP. For some reason, they left that functionality out in Win 2000.
Brandon Martus
e-mail
Unread 05-11-2002, 16:42
Crusty Mentor
FRC #0097
Where exactly do you set one as primary and one as secondary? I don't see that option anywhere in display properties.
Dan L
Team 97 Mentor
Unread 05-11-2002, 16:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
New plan. First things first, the Viper is a TNT card. I had one back in the days.
Now then. I suggest you try making yourself a restore point (just in case) then pulling your AGP card and trying to run with just the PCI card. It could be that it's not compatible or friend or something. If it does work, lemme know, and I'll think of something else for you to try.
Edit:
Go into your displays properties thing. if you see two rectangles with a "1" and "2" inside them, then you should be able to get things to work. if not, then the vid card isn't working yet, and the two monitors thing won't work yet.
Unread 05-11-2002, 16:55
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
There's two things that can make an older card stop working: An incompatible or conflicting IRQ address, or an incorrectly set COM port.
Did the Viper work on the same machine before you put in the new card? Or is the Viper the card you've added to the system? If you moved the Viper from one slot to another to make room for the GeForce, the Viper might not work, because it wants to stay in the old slot, and if it's being added, it needs to know what slot it's in.
Take a look at the Viper… if it has jumpers for different IRQ numbers and different COM port numbers, that’s probably what’s wrong. Nowadays, instead of COM ports, these are called PCI slots… And older cards need to know what slot they're in to function correctly, even if they claim to be PnP.
So did you move the Viper, or is it being added?
And IRQ #s... Windows can put multiple devices on the same IRQ # without having a conflict, so it's a little hard to figure out. You have to use the BIOS, sometimes, to see if two devices are on the same number. Old diamond cards like to be on IRQ 5 or 7 , If I remember. (I had a Diamond card, long ago...)
For my own dual-monitor setup, I use my GeForce plus the card built into the motherboard, but I don't plug two monitors in too often.
See if the COM theory is correct, then worry about the IRQs...
If you want, you can IM me at AIM: ZImperial1 or MSN: GrandAdmThrawn@msn.com
Unread 05-11-2002, 17:15
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Lightbulb It does work in Win2k
As far as multiple video cards in Win2k goes, I've got an old Pentium Pro 200 MHz workstation at school with a Matrox Millennium and a Matrox Mystique (both PCI, 2 Mb, 220 MHz each -- yes, "faster" than the main processor! ) running together with no problems. Both work at resolutions of 1152 x 864 (and higher) without any problems in Windows. The system runs Win2k SP3, and I'm not using any special programs or drivers, apart from the defaults that come with Windows. All I had to do was plug the cards in, and they worked perfectly well.
Now, when I decided that, just for the heck of it, I'd add a third video card, a S3 Trio64V+ (or something like that), it had the same "cannot start device" error that someone else reported, but did not affect the other two monitors (it's out now, since it was just taking up a slot!).
There were some issues, a few years ago about using an AGP card along with a PCI one (in Win98, I think), but that shouldn't be a problem in WinXP or Win2k.
Also, it's very rare to have to modify Windows' IRQ settings these days, especially with PCI or AGP cards. Do you have any old hardware installed on the ISA bus, if present (modem, NIC, sound card, etc.)? You might try pulling those out temporarily, to see if there are any incompatibilities there.
Unread 05-11-2002, 17:26
busy.
AKA: B. Slash Kamen
Re: It does work in Win2k
Originally posted by Tristan Lall
...shouldn't be a problem in ... Win2k.
It may have just been the video card in my laptop that was compatable with everything but win2k. I don't rememeber offhand.
Brandon Martus
e-mail
FRC Key Volunteer Trainer
AKA: CrazyNate
The catch, as I've seen it, with multiple video cards, is finding a card for your second(or third, or fourth, etc.) card that does not require its BIOS to be initialized to work correctly. Your average computer can only initialize one video BIOS during bootup, so if you have more than one card that need initialization in use, you will get the "cannot start device" error that you are experiencing...
Nate Smith
nsmith@smythsoft.com
Unread 05-11-2002, 19:17
Crusty Mentor
FRC #0097
Alright, thanks for all the help, guys.
So heres what I've done. Like I said, my cisco teacher was throwing out several oldskewl computers, so I grabbed several '96 video cards. Anyways, so now I had three cards - the Quadro (AGP), the TNT (PCI), and the generic Trident card(PCI).
I put each into the computer by itself. By itself, each card worked fine.
I put the Quadro and TNT in. The Quadro worked, but the TNT got the error message. I took the TNT out and put Mr. Generic in. The Quadro worked but Mr. Generic didn't.
Then I took the Quadro out and put the TNT and Mr. Generic in. The TNT worked but Mr. Generic got the error message. When I switched slots, Mr. Generic worked but the TNT got the error message. Most likely what happens here is that the AGP slot is checked for a video card first, then the PCI slots in a specific order.
I doubt this is a Windows thing, because if it was, the card would display the BIOS screen and then stop - which doesn't happen. As for the IRQ's, when the card has the cannot start message, it isn't even assigned an IRQ (back in the day, my video card got to share the IRQ with my nic.... you have no idea how long and how many black-screen-with-green-hashes-which-is-b.o.s.-equivalent-of-video-card-crash crashes I went through before I learned the problem was the IRQ).
So, basically, the cards work fine by themselves. The problem therefore must be specific only to the case where two are put in at the same time. Since the card which is recognized first works fine, the problem applies always to the secondary card. So I'm led to believe in Nate's explination. Nate - do you have any more information about this issue? Like is it specifically the motherboard, or the card, or both? Would the instruction manual contain information about this? Do cards specifically say somewhere that their bios doesn't need to be initialized for the card to work? How can I make sure this is the problem?
Thanks for your help, everyone!
Dan L
Team 97 Mentor
Unread 05-11-2002, 19:28
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Hmm. I totally forgot that I have about 5 PCI video cards and a spare monitor. *does some digging this evening*
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 05-11-2002, 19:55
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
What do you want this for Video Mirroring or to set up monitors that display a portion of the screen?
One possibility is to make sure that your are on a fixed resolution and refresh rate that both of video cards can support. If they are on a resolution or refresh rate that the video card can't handle, it won't even get you a screen.
Another possibility is that the video cards have incompatible technology, especially when they are made by two different companies. I have heard a lot about incompatibility with some games and multiple video cards.
I really wish I could help you more, but I haven't encountered a problem like this before.
Unread 05-11-2002, 20:36
AJ Quick's Avatar
Just FYI, Windows selects the PCI as the primary for some reason. Try hooking one monitor up to the PCI, and then right-clicking on the desktop, to configure the display adapters. Set the PCI as the master, then the AGP will be secondary... then with the AGP adapter select the "Extend Desktop Onto This Monitor".
I think I had a problem like this when I installed my second video card in this machine a few weeks ago. Setting the PCI as primary cleared it up.
Unread 05-11-2002, 21:11
AKA: CrazyNate
Your best bet is to look online for each specific card, to see what you can find about it...and it is card-specific, not motherboard...based on what you're describing, what I earlier described sounds like the most likely cause...I actually ran into this same problem myself a while back...
Nate Smith
Unread 05-11-2002, 22:34
Crusty Mentor
FRC #0097
I want basically one desktop on two moniters - one per video card. As for the refresh rate, the secondary card is never actually in working mode, so you can't change any display properties or such for the problematic card. You're going a bit further than where the problem is.
Dan L
Team 97 Mentor
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
[white paper] Dual Motor Gear Switching Assy Brandon Martus Motors 0 29-06-2001 12:56
