Go to Post "I want to be like them. We will strive to be like them. Lets get started! :D " - Rion Atkinson [more]
Unread 11-02-2011, 20:23
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Autonomous-Analog Signals?
We are trying to get a potentiometer to turn on a motor when a potentiometer voltage is 4.8V. Our problem is the ANALOG CHANNEL_GET VOLTAGE VI only gets the voltage from the potentiometer once. We need it to keep reading the voltage until it reaches 4.8V.
Unread 12-02-2011, 05:49
Re: Autonomous-Analog Signals?
Assuming this is in Autonomous, put a small loop around the Read Voltage and the compare.
You may also want to consider other conditions which would stop the loop and turn off the motor. In other words, is there a time limit that makes sense, or should the motor run no matter what until the switch is hit. You may also want a small delay in the loop -- check every 10ms or so.
Greg McKaskle
Unread 12-02-2011, 09:18
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Careful with the above suggestion. Using a while loop should work fine in autonomous but realize that you cannot reuse this code in teleop mode. You cant use these loops in teleop mode because while you are evaluating the loop, the cRIO isn't updating any of the PWM ouputs. This will consequently cause a watchdog error. Instead there is a block under timing which evaluates a set time and outputs a boolean when it has elapsed and can be easily reset.
Hope this helps,
baronep
Unread 12-02-2011, 10:51
FRC #2147
Thanks! I inserted while loops and now the autonomous code runs beautifully. I also ran the DS practice mode and had no problem (watchdog errors) transitioning from autonomous to teleop.
Thanks All!
