Re: Tetrix Thermal-Protected DC Motor Power Cable Modifications
There's nothing that says you can't solder things on your minitbot. There's nothing that says you can't modify the motor cable. You do, indeed, need to be careful when soldering to the motor. Pre-tin both the motor pin and the wire with solder and then melt them together in the last step. A heatsink at the base of the motor pin would also be a good idea.
Even if it was legal, what advantage would you gain by doing this?
It's more reliable. We know that the wires will not fall out of thier connectors. We had this problem a lot with prototyping and didn't want to risk anything when it comes time for competition.
You need to provide strain relief for your wires. Try cable tying the wires to the motor body and you shouldn't have any reliability problems. |
Imagine though if you did solder the wire and the motor then failed, now not only do you have to replace the motor, but also the cable. |
If you solder wires on the motor be forewarned that the plastic holding the terminals is extremely heat sensitive and melts rather easily. The temperature required for lead free solder makes the plastic turn to jello. With the resulting moving of the terminals. And if they move the connection to the internal brush tab will likely be broken. Then you will need to open the motor rendering it useless for competition.
#7
