Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 12-02-2011, 13:02
Bennio Bennio is offline
FRC #2495
Bennio is an unknown quantity at this point
Pneumatic Pressure Switch Programming
Hey there,
We just started hooking up the pneumatics on our robot, and I'm responsible for programming it. We have a pressure switch attached to the system, but I need to know whether or not I need to program with it, or if it's automatic. Also, is there a specific VI that receives data from the switch? Help is much appreciated, I don't want to explode anything accidentally!
Unread 12-02-2011, 13:29
Mtg Ruler Mtg Ruler is offline
FRC #1986 (Team Titanium)
Mtg Ruler is an unknown quantity at this point
Re: Pneumatic Pressure Switch Programming
If it is the required pressure switch, then you will wire the ends into a DIO port, and in the Open Compressor VI, specify which channel and slot you have that it is wired to. That VI should do the rest.
That switch should shut off the compressor when it reaches 120psi, just so you know if it is wired correctly or not.
Unread 12-02-2011, 13:49
FRC #2495
Talking Re: Pneumatic Pressure Switch Programming
Thanks, that's just what I needed to know!
