Go to Post geeez....and i was going to say they should knock a week off the build season. - johnr [more]
Unread 12-02-2011, 14:44
JMillar's Avatar
JMillar JMillar is offline
FRC #2172 (Streetleagle)
JMillar is an unknown quantity at this point
Hostbot Clearing the Tower
Does your hostbot/robot have to not be touching the tower, be out of the tower's base perimeter, before your minibot passes the deployment line?
Unread 12-02-2011, 14:50
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
Re: Hostbot Clearing the Tower
If you are in the process of deploying, then <G20> reads that
ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
This means that you can touch the tower, you just can't touch it above the deployment line.
Just remember to keep <G17> in mind, that you can't deploy during tele-op.
"The Few. The Proud. The Skunks."
Unread 12-02-2011, 16:08
phoenix_fire's Avatar
phoenix_fire phoenix_fire is offline
FRC #2489 (Insomniacs)
phoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the rough
Along with <G20>:
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled
So, you can touch the tower if your minibot is above the deployment line, you just can't touch your minibot at the same time.
FRC 2489 Insomniacs
FTC 548 & 596 Geek Squad and Transformerz
