Go to Post Each team should ask not what their alliance can do for them, but what they can do for their alliance. - [more]
Unread 12-02-2011, 15:54
bhs2876 bhs2876 is offline
FRC #2876
bhs2876 is an unknown quantity at this point
How to power a minibot
Currently we have a minibot composed of Tetrix parts. We also have a Mindstorms brick connected to the motor of the minibot. We were wondering how to turn the minibot on, as well as how to power it after it's deployed without being able to use stored energy i.e. springs.
Unread 12-02-2011, 16:21
phoenix_fire's Avatar
phoenix_fire phoenix_fire is offline
FRC #2489 (Insomniacs)
phoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the rough
Re: How to power a minibot
To have the minibot move up the tower you can use up to two Tetrix motors.
As for getting it to start moving, there are ways to wire switches into the circuit. I recommend searching CD for other discussions about switches.
If you use switches, you don't need the NXT brick, losing weight.
If you are planning on using the NXT, have something that presses the orange button. A servo with a stick for example.
FRC 2489 Insomniacs
FTC 548 & 596 Geek Squad and Transformerz
Unread 12-02-2011, 17:12
Loremispum Loremispum is offline
Loremispum is infamous around these partsLoremispum is infamous around these partsLoremispum is infamous around these partsLoremispum is infamous around these partsLoremispum is infamous around these parts
I was thinking that you would use batteries to power the minibot...
Unread 12-02-2011, 17:35
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
You can leave the minibot's battery on, and to make the minibot move you can either use a touch sensor or make the orange button on the NXT act like a touch sensor and then have something touch it. Another idea is to use a NXT light sensor, then when the minibot is ready to go up, shine a bright LED onto the light sensor (can be controlled by the hostbot)
