illegal
does anyone have a list of motors for previous years that are illegal this year. if you have pics of them two that would be awesome
Re: illegal
Van Door: black, looks kind of like a window motor with an extra-long shaft. Discontinued after 2004, IIRC.
Drill motor: looks a lot like an FP. Often found in pre-2005 drives. Taigene window motor: silvery version of the Densos. Don't remember when it was discontinued. Mabuchi motor: looks like a BB motor, no gearbox. Don't remember when it disappeared; it was used in 2005. Seat motor: so old I don't remember what it looks like... discontinued after 2002. Globe motor: looked like a BB with a black gearbox on the end of the same diameter and a shaft with a flat on it. I forget when it was discontinued; probably shortly after 2004. Any particular reason you're asking? |
Re: illegal
You CAN use: 4 CIMs, 2 Right Window, 2 Left Window, 1 F-P, and 4 BaneBots motors in any combination |
Re: illegal
The question asked was effectively, "What motors used to be legal that are not, and what do they look like?" I forgot one: the pre-2011 FP motors are now non-legal. |
Re: illegal
Eric's list is pretty comprehensive, but he did forget one motor, the large CIM.
I believe it was offered in the kit from 2005 to 2007, it was approximately 3" in diameter whereas the current CIM is 2.5" in diameter. The dead giveaway, if you can't tell by the size, is that the large CIM had a pulley and tensioner attached. |
Re: illegal
Re: illegal
What about motors from previous motors are any of those illegal?
Like ones from 2008 and newer? |
#8
Re: illegal
I can't recall any others offhand. Any particular reason you're asking? |
#9
Re: illegal
The Globe motor was discontinuted in 2010. The last kit it appeared in was 2009.
#10
Re: illegal
we are using a motor for our arm and one of our team mates said it was illegal and i do not know what the motor is called i believe got it last year
#11
Re: illegal
this is what the motor looks like
#12
Re: illegal
That's a window motor, so it's either a Taigene or a Denso.
My best guess is it's a Denso, as the Taigene gearboxes tended to be metal. Next question: Does the part number match the part number on the KOP checklist? If so, and you aren't using another 2 of that type, you're OK. If not, you're not OK. |
#13
Re: illegal
so any motor is legal as long as we put it on our BOM list
my question is what makes a motor illegal |
#14
Re: illegal
no. there are lots of illegal motors. assume a motor illegal until proven legal.
what makes some motors illegal is not being in this year's KOP or being one too many of a legal motor. read the manual! Quote:
the globes were KOP as late as 09 as well... my team at the time used one for a turret; my current team as well as 1024 used 4 to steer crab modules that year. IIRC they were legal in 10. there were also various mabuchi motors (same co. that makes the FP) that were legal last year... but not this year. not sure on when they were KOP. the window motor above doesn't look legal. the threaded insert was aluminum, not copper. also, the contact covers were white, not black. Last edited by ratdude747 : 12-02-2011 at 19:49. |
#15
Re: illegal
Any motor is legal, as long as its Part Number matches one that is one the KOP checklist, or is specifically allowed in the Manual. So, 4 CIM motors 1 FP (2011 Model) 2 Right hand Denso Window Motors 2 Left Hand Denso Window Motors 4 BaneBots motors, any combination of the 4 allowed models. |
