Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 12-02-2011, 19:04
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
AndrewD is an unknown quantity at this point
Exclamation Original XBOX Controller Legal?
I was wondering if it is legal to use an original xbox controller in competition. Also if it is legal, since it needs to be modified, does that mean we cannot use it in any other years?
Thanks in Advance,
Andrew
____________________________________________
FRC Team #1243 - The Dragons
Unread 12-02-2011, 19:18
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Original XBOX Controller Legal?
what do you mean by original controller?
Unread 12-02-2011, 19:22
AndrewD's Avatar
AKA: Andrew Dolio
FRC #1243 (Dragons)
You know, like the predecessor to the xbox 360?
Unread 12-02-2011, 21:19
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
You don't need to modify the controller. You can buy little boards which will plug into the cable at the break-away point then go to a USB connector. It's just a simple PCB w/ 4 traces. (i can't find a link to it any more, but here's a cable... http://secure.llamma.com/catalog/pro...products_id/78)
After that it's just a matter of installing the USB driver and you should be good to go.
I don't see why you wouldn't be able to use it in this configuration every year.
Unread 12-02-2011, 21:38
AndrewD's Avatar
AKA: Andrew Dolio
FRC #1243 (Dragons)
I have already made an adapter but I thought I saw in the rules that anything modified from its original state was considered part of the robot and cannot be reused.
Unread 13-02-2011, 13:54
Are you intending to put the controller on the robot? Or is it just going to be part of the operator console?
