Re: Axis 206 camera
The default code from 2008 did a servo mounted camera, and because of that, there is a Two Color Servo Camera Example that ships with LV. You can open it form the Help menu or the getting started. The code is a bit complex because it was trying to quickly process and follow the green/pink cylinder, but you can see how the bottom loop moves the camera around.
Greg McKaskle |
