Go to Post This year should be an unusual object game. You know what an unusual object is? Water. - TheBoulderite [more]
Unread 12-02-2011, 21:11
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
3 position cylinders
Rule <R74> says that
Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve.
Does this illlegalize 3 position cylinders, or are 3 position cylinders legal because they are technically 2 cylinders put together?
Unread 12-02-2011, 21:22
Electrical Engineer
Rookie Year: 1995
Re: 3 position cylinders
Originally Posted by implosionprez View Post
Rule <R74> says that Does this illlegalize 3 position cylinders, or are 3 position cylinders legal because they are technically 2 cylinders put together?
You should ask the GDC officially.
Mike Betts
As easy as 355/113...
Unread 12-02-2011, 21:37
AKA: Ty
Has anyone asked the GDC yet?
Unread 12-02-2011, 21:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
not from my quick hour of looking, but don't limit yourself to the "Pneumatics" section. Pneumatics can be found all over the "the Robot" section of the
Q & A.
Unread 12-02-2011, 21:44
Ty,
Can you provide a link to the actuator you are asking about?
Unread 12-02-2011, 21:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It seems to me that one valve means one valve.
Here's how you plumb a 2-port 3-position cylinder with a single 5/3 valve.
This 3-port arrangement probably wouldn't work for you, unless you found an appropriate valve.
Unread 12-02-2011, 21:53
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Here is a Bimba 3 position. We may use one. I have posted in the Q+A.
http://bimba.com/pdf/catalogs/FL_Ori...ne.pdf#page=67
Here is a pdf explaining how they work.
http://www.bimba.com/pdf/catalogs/TRD_3P_Series.pdf
I don't know what the GDC will say, but I would say these are safer than connecting multiple cylinders together at the clevis or foot end, because these are built as a joined pair.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 12-02-2011, 21:56
AKA: Ty
Here is a link to the 3 position cylinders. My only worry is that it's a violation of <R74>. http://www.bimba.com/Products/Origin...tionCylinders/
Unread 12-02-2011, 22:01
Rookie Year: 1942
<R74> Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve. Plumbing the outputs from multiple valves together into the same input on a pneumatic cylinder is prohibited.
I posted the question.
My interpretation is that the three position cylinders are legal, as long as you only have one solenoid connected to each input. The rule does not say one solenoid connected to each cylinder.
I will post the response from the GDC when I see it.
Chris Fultz
Unread 12-02-2011, 22:02
AKA: Ty
Ty,
I can't post a link (immediately) because a moderator has to approve it, but These cylinders from Bimba are the ones I'm talking about. I worry about <R74>, because it's technically one cylinder, with multiple solenoids, but it's also technically two cylinders together.
Unread 12-02-2011, 22:49
Ty,
I do not see that the use of this cylinder and multiple solenoids would violate R74. R74 specifically is written to prevent more than one valve to feed the same input on a cylinder in an attempt to make the cylinder react faster. I must abide by by the ruling of the GDC and I have been wrong before. Please standby until they respond.
Unread 12-02-2011, 22:54
AKA: Ty
Will do. Thanks for checking!
Unread 16-02-2011, 13:47
Rookie Year: 1942
http://forums.usfirst.org/showthread.php?t=17069
Re: 2 Stage Bimba Cylinders
As long as <R74> is followed and "each commanded motion of a pneumatic cylinder is accomplished via the flow of compressed air through only one approved pneumatic valve" and these cylinders meet the requirements of <R66>, the cylinders are allowed.
Chris Fultz
Unread 16-02-2011, 14:27
Racer26 Racer26 is offline
Interesting note: Does <R74> as written outlaw the design 1075 used in 2004 and 2007 for stopping a pneumatic cylinder mid-stroke?
By passing the exhaust ports of a valve into the P port of another valve, with a looped hose connecting A and B, plugging EA. This seems like TWO valves controlling the flow through that ONE cylinder, though only ONE valve is DIRECTLY connected to the cylinder.
Unread 16-02-2011, 15:02
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
bstrong1218 is an unknown quantity at this point
No clue if it's just a negative externality of the pneumatics rules this year, but position control with multiple solenoids or even a single 3 position, normally closed solenoid seems to have been outlawed.
Check the official Q&A... our team asked about what you're describing as did a few others and the answers point to a violation of <R74>.
