Go to Post We're somewhere in the range of ludicrous speed to bench grinder. - Ginger Power [more]
Unread 12-02-2011, 21:12
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Re: Issue with autonomous mode and some newbie questions
Thanks for the help. I will let you know how it goes when I test out the code on Monday.
Can someone answer questions 3 & 4 in the first post?
3. How do you save as project (not .java file) on a usb drive or on a different location from where it was originally saved?
4. How can I debug the code using System.out.println? It never prints out anything. Are there other ways for debugging the code or knowing what values you get from sensors?
