Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2011, 21:17
Dr Fritz's Avatar
Dr Fritz Dr Fritz is offline
AKA: Fritzelin
FRC #1165 (Team Paridise)
Dr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura about
Re: Polycarbonate....
this is true I have another thread about ball bearings made out of raw materials so what about PVC does it as well have a lot of friction?
ph.D Asskickanomics
Magnets work well
Thor Protector of Man kind
Raise your swords up high
See the black birds fly
Let them hear your rage
Show no fear
"Our Mini-bot goes 'clink-whee"
Unread 12-02-2011, 21:52
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
PVC won't be very good as a bearing—it's weak and soft. Besides, only specific types of PVC are allowed, so you'd be stuck machining your bearings from PVC pipe and fittings (and fasteners, if you can find any, and the above theory holds). (That would be unbelievably annoying to make.)
If you're referring to using PVC as a roller or sliding plate without a bearing, then I think it ought to be a bit better than polycarbonate.
Unread 12-02-2011, 21:59
Dr Fritz's Avatar
AKA: Fritzelin
i mean we are thing roller or bearings you know ok so as a roller better then ploy?
ph.D Asskickanomics
Magnets work well
Show no fear
