Go to Post I design gears and gear boxes for a living. I am HAPPY to write a check and have a solution in mailed to me. - Joe Johnson [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2011, 13:24
Dr Fritz's Avatar
Dr Fritz Dr Fritz is offline
AKA: Fritzelin
FRC #1165 (Team Paridise)
Dr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura about
ball bearings....
could we use ball bearings on the mini bot? yes i have looked at <R92> over and over, but what do you guys think something like a ball bearing made out of material we can use.
ph.D Asskickanomics
Magnets work well
Thor Protector of Man kind
Raise your swords up high
See the black birds fly
Let them hear your rage
Show no fear
"Our Mini-bot goes 'clink-whee"
Unread 12-02-2011, 15:09
GaryVoshol's Avatar
Cogito ergo arbitro
Re: ball bearings....
Make'm out of polycarb or aluminum - go for it. But you have to make the bearings; those materials are "raw" materials allowed only.
(since 2004)
Unread 12-02-2011, 16:10
Dr Fritz's Avatar
AKA: Fritzelin
why polycar or aluminum why not delrin?
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 16:42
phoenix_fire's Avatar
phoenix_fire phoenix_fire is offline
FRC #2489 (Insomniacs)
phoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the rough
Delrin isn't allowed by <R92>. As stated, your ball bearings have to be manufactured by materials allowed in <R92>.
FRC 2489 Insomniacs
FTC 548 & 596 Geek Squad and Transformerz
Unread 12-02-2011, 16:45
Dr Fritz's Avatar
AKA: Fritzelin
thats what i thought thanks guys
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 21:15
Dr Fritz's Avatar
AKA: Fritzelin
so what about PVC does PVC come in plastic balls or pellets
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 21:17
GaryVoshol's Avatar
Cogito ergo arbitro
Doesn't matter if it does or doesn't. <R92> only allows PVC pipe or fittings.
I misspoke above - you can use polycarbonate in any form, whether it's something you fabricate or something you buy.
Aluminum, you can only use things you make out of raw stock, or Tetrix parts.
(since 2004)
Chris is me's Avatar
AKA: Pinecone
Polycarbonate is by no means required to be in raw material form - that restriction only applies to aluminium.
Not legal either--the only PVC allowed is in pipe or fitting form.
Unread 12-02-2011, 21:20
Dr Fritz's Avatar
AKA: Fritzelin
that is what I thought ok, I was not sure if there was anything else I could do to them. what about using the PVC as a roller part its still in pipe form?
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 21:26
GaryVoshol's Avatar
Cogito ergo arbitro
It doesn't have to be used in pipe form - you can cut it or do whatever with it. You can only buy PVC in the form of pipe or fittings though, to stay in compliance with <R92>.
(since 2004)
Unread 12-02-2011, 21:30
Dr Fritz's Avatar
AKA: Fritzelin
um can I possibly get a direct answer with this?
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 21:49
Doc,
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components that are not in violation of any other rules, (Tetrix components are listed in Approved Tetrix Parts at www.usfirst.org/frc/competitionmanual),
F. Polycarbonate,
G. Polycarbonate glue,
Q. PVC or CPVC pipe and fittings,
R. PVC cement or cleaner
Yes you may use pipe as a roller. The Tetrix allowed parts list has one type of ball bearing that is legal for your use and one sleeve bearing.
Unread 12-02-2011, 22:01
Dr Fritz's Avatar
AKA: Fritzelin
i know that but can i modify my PVC pipe into something that's not a pipe
ph.D Asskickanomics
Magnets work well
Show no fear
Unread 12-02-2011, 22:38
If it started life as a PVC pipe and an inspector can tell that it's heritage is traceable to a PVC pipe then it may be used in a modified state.
