Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 12-02-2011, 21:36
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Reading Battery Voltage
Originally Posted by Matt Krass View Post
The black motor terminal of the Jaguar is not a valid common node, it can be connected to both the positive or negative or neither depending on what the Jaguar is doing and how it is configured.
The black power input to the Jaguar (directly across) should be acceptable to use though, at least as far as multimeter probes go.
I don't have one in front of me right now, but I seem to recall that the inputs to a Jaguar use red and black screws and the outputs are colored green and white. The "black" terminal I was referring to was the input side of the Jaguar.
And, Al's right, there's no "ground" in the most literal sense on the robot. My use of "ground" could have probably been better worded as the EE colloquial "virtual ground" (i.e. the node of the circuit from which voltage is measured) or as "common". The chassis being electrically isolated (therefore there is no ground) is an important and sometimes overlooked detail in the FRC.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
