Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Unread 12-02-2011, 23:20
MEOWMEOW MEOWMEOW is offline
FRC #2443
MEOWMEOW is an unknown quantity at this point
Classmate is not changing numbers or colors HELP!!
On the classmate computer why is the readings of the Analog Imputs, PWM, GPIO, and Relay not lighting up when the program is running. Whats much werid is that when we play our program it works like the robot moves but the readings are not changing color or changing their numbers. What do we do to fix this? What is actually causing this?
Unread 13-02-2011, 01:46
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Classmate is not changing numbers or colors HELP!!
If I remember correctly (and it's been a while), the dashboard (the top half of the driver station GUI) only displays data that you explicitly send it. The default dashboard happens to show GPIO, PWM, etc, but just setting the robot outputs doesn't cause the dashboard to show them.
How you send the data to the dashboard obviously depends on which programming language you're using on the robot. For Java/C++, take a look at the Dashboard class and the dashboard section in the WPILib user guide.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 13-02-2011, 07:33
The LabVIEW default framework sends quite a few values back in the team VI "Build DashBoard Data.vi", but I'm not sure about the other frameworks. If using LV, open RobotMain and see if the loop still contains the call to build the dashboard data. You can also open it so see if the settings or code were changed.
Greg McKaskle
