Go to Post I suppose you need to let the kiddies (including Copioli) win a few now and then. - Andy Baker [more]
Unread 12-02-2011, 23:25
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: pic: Banebot P60 Failure
Another thing to look out for is the roll pins that hold the outer ring gear to the front plate. The wall on the roll pin holes bend and lets the flats on the ring gear slip which ends up rounding the whole front of the gear. I can see it already happening to this gearbox.
Install a torque limiting sprocket to take care of some of that shock load at ends of travel if your using chain.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 13-02-2011, 09:05
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
The 4 roll pins have already stripped out of the front bearing mount, but I believe that we may be able to press new roll pins in - I'm not sure yet.
Our mechanism is designed so that the gearboxes themselves should never "see" more than 15-20ft-lbs of torque. The majority of the damage done to these gearboxes was done when I was testing an arm fix and went from full speed up to full speed down, something that the operator does not do in competition.
-Dustin Benedict
Unread 13-02-2011, 13:48
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
If it can happen it will happen. I am with Adam on this one and would redesign it so you can't see more torque than the transmission is spec'd for. Just because you normally wouldn't operate in this fashion, if it does happen, I wouldn't want to be the one begging a team for a spare transmission at competition.
-Michael Dessingue
Unread 13-02-2011, 13:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What is the overall ratio? How heavy and long is the arm? Is it counterbalanced?
I'm just curious about the conditions prior to failure. We have a similar implementation using a BB 81:1 gearbox and have beat on it pretty hard over the last two days. We haven't experienced any problems yet, but if our implementation is similar to your, I may tear the gearbox apart and take a peak inside.
--Madison--
...down at the Ozdust!
Unread 13-02-2011, 14:17
Chris is me's Avatar
AKA: Pinecone
Dustin,
Aren't you already slowing down the arm in software? All you need is another stage of chain reduction and you'll dramatically decrease the load on the gearbox, increase the output torque on the arm, and fix every problem you have.
Unread 13-02-2011, 14:44
thefro526's Avatar
Mentor for Hire.
The overall ratio is approximately 819.2:1. The Banebot Transmission itself is a 256:1 ratio, and there is a 3.2:1 ratio after the transmission which drives the arm. The arms themselves are approximately 57" long with a 7lb load on the end. We also have some surgical tubing on the arm so it's effectively lifting a 1lb load at the end of the arm, and that load is being lifted by two RS775-18's through two 256:1 transmissions.
Originally Posted by Chris is me View Post
Dustin,
We were planning on slowing the arm down in software if we found the need to. We may implement a 2nd reduction after the transmissions, but we'll need to see if this is physically possible with our system. A more likely solution is to swap the 15 tooth drive sprocket on the transmission to a 10 tooth drive sprocket which would give us an effective 4.8:1 ratio after the transmission.
I just want to say that they did not fail under "normal" use, they failed during a test in which I tried to get them to fail. I cycled our arm at the highest load point from 100% forward to 100% backwards a half dozen times before getting any sort of play in either transmission. One transmission failed, while the other was fine. (The drive sprocket for the arm was not tightened properly during re-assembly which appears to have caused one side to see more force than the other, but I'm not sure).
Note: This picture wasn't meant to start a discussion about our system, but to provide a visual record of a failed P60.
-Dustin Benedict
Unread 13-02-2011, 16:57
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Our failure point was those spring pins getting torqued off the flats also. All the gears are fine. We removed the spring pins and drilled out the pin holes for larger pins going deeper into the face plate. Then put divots where the pins interface the flats for the pins to seat in. Seems better than new this way and running good now.
www.179swampthing.org
Unread 13-02-2011, 17:03
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I am very interested to hear how this works out over the long run. I wonder if banebots designed these pins to shear off first to protect something more exspensive in the assembly.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-02-2011, 18:25
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
If they can fail in a test, there's a decent chance they can fail in a real situation, too... Wouldn't you rather fix it now, instead of hoping these same circumstances can never repeat themselves in competition?
Extra chain reduction and some surgical-tubing counterbalancing could solve your problem. BaneBots gearboxes work much better when you treat them nicely...
Jeff Waegelin
Unread 13-02-2011, 20:50
thefro526's Avatar
Mentor for Hire.
You're right, we are planning on modifying a few things to make the mechanism more "nice" to the P60's, though we don't feel that a full on redesign is necessary. There's already quite a bit of surgical tubing on the arm, and we plan on adding a bit more when we get our next McMaster-Carr order. We're also considering swapping out the drive sprocket to a 10 tooth which should make the transmissions see about 33% less torque during operation - not to mention that the arm should slow down a bit too.
I'm also going to look into the modification that Swampdude suggested and see if we're able to do it in our shop.
-Dustin Benedict
