Go to Post So go out and learn something new, even if it is old. Co-operate in this and you'll get much more out of it. Cheat and you are only cheating yourself. - ChrisH [more]
Unread 12-02-2011, 23:41
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Team 1322 claw for 2011
Unread 12-02-2011, 23:43
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: pic: Team 1322 claw for 2011
Correct me if I'm wrong, but it seems like your polycord all turns in the same direction. You might want to consider making an "X" with the polycord in the middle to reverse the direction of one of rollers if that's the case.
Unread 12-02-2011, 23:46
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Except if the purpose of the polycord is to rotate the tube once it is inside the clamp.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-02-2011, 00:12
Chris is me's Avatar
AKA: Pinecone
Why rotate the tube with rollers when you could put the gripper on a wrist joint?
Unread 13-02-2011, 00:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
KISS. If the top and bottom are run by two different motors, why add a degree of freedom you don't need for your design?
1058 PVC Pirates 2016 - xxxx
Unread 13-02-2011, 00:31
AKA: Pinecone
For a roller claw I completely agree, but this is a pinch claw with rolling cord used for spinning. The rollers wouldn't otherwise be on there at all.
Unread 13-02-2011, 00:35
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Interesting that there's two rollers on the bottom and one on the top. Wouldn't that route 2/3 of the power to the bottom rollers, such that if you try to rotate the tube upwards it'd mostly just make a quick exit? Or would the pinch hold it in?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 13-02-2011, 00:44
AKA: Logan
I'm not sure if this intake will even get the tube inside the clamp without some sort of "pulling" force" (like the one made with two opposing rollers)
Unread 13-02-2011, 09:32
joeweber's Avatar
Coach team 1322
Our design in on a vertical lift. When a tube is inserted into the claw in automatically closes than we can rotate the tube vertically. We do this so we do not have to raise the lift the additional 30 inches to get the tubes above the hook post. We also can tilt the whole mechanism down to the floor for floor pick up. If the cords were going the wrong direction it would not work for us but it works very well.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
