Go to Post Heat Gun(n.):Your build season replacement for a microwave. - jajabinx124 [more]
Thread Tools Rating: Thread Rating: 23 votes, 4.96 average. Display Modes
Unread 13-02-2011, 01:46
lusterlink's Avatar
lusterlink lusterlink is offline
FRC #1160 (FireBird Robotics)
lusterlink is an unknown quantity at this point
Re: NetBeans robot communication/subnet problems
Originally Posted by Jose.Pena2737 View Post
I'm having the same problem.
What happens after it gives me the subnet error, It says it's trying to connect to "FTP@ 10.0.0.2" even though our cRIO's IP address is 10.27.37.2.
If I change the cRio's IP to 10.0.0.2, it leaves me hanging on "Overload Me".
I've gone through various updates(I was having this problem two weeks ago, back then, the cRIO image was v25, now it's v27) and nothing has worked.
I would appreciate some help.
I believe this means you haven't set your team number in the preferences of Netbeans. It should be under Tools -> Options -> Miscellaneous ->FRC Configuration. Keep the cRIO's ip at 10.27.37.2.
[cRIO] RobotInit() completed.
[cRIO]
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
Are you enabling the robot and getting the same output in Netconsole? Otherwise, I think enabling the robot will fix your problem.
Unread 15-02-2011, 21:53
Jose.Pena2737 Jose.Pena2737 is offline
FRC #2737
Jose.Pena2737 is an unknown quantity at this point
Thank you! we have a connection.
Unread 24-01-2012, 18:28
Billy_499 Billy_499 is offline
FRC #0499
Billy_499 is an unknown quantity at this point
I am the programmer of team 499. I have been using lab view since my freshman year but this year our teacher said That we will be programming in java this year. Mine hangs at "overload me!" as well and I literally have no clue on how to proceed. Please help with detailed and simple instructions.
Sincerely,
Billy team 499
Unread 25-01-2012, 00:23
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Sincerely,
Billy team 499
That's probably not hanging. Most methods for robot templates will print out 'overload me' until you overload them. But you usually don't need to overload very many methods. (often just one autonomous and one teleop method) As mentioned below, just stick your drive code into a method like teleopPeriodic (there are probably better ones) and Enable the robot in the right mode.
Definitely take a look at Java samples included with the java plugins.
Unread 26-01-2012, 10:59
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
What you guys need to do is go into your netbeans options and go to Misc. then from there you will see a tab named FRC config in that tab you need to set your team number to be whatever it is and then it will deploy code to 10.xx.yy.2 instead of 10.0.0.2, also even though the cRio tells you to overload the method the robot should still be able to run.
Unread 26-01-2012, 17:20
FRC #0499
How would I overload it?
