Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 13-02-2011, 09:18
pbawesome pbawesome is offline
FRC #1100
pbawesome is an unknown quantity at this point
Re: Washers on Sprockets
a spacer would be best. measure out some low profile nuts (or normal nuts if you need alot of spacing) and thread them onto the wheel then attach the sprocket. The washers are a really bad idea! the sprocket may go all over the place and knock the chain off!
so use either nuts or turn down some spacers out of PVC
Unread 13-02-2011, 09:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Spin the wheel without chain attached to it. If the sprocket doesn't wobble, you're fine. in other words, if the sprocket is perfectly parallel to the wheel, you're fine.
If it does wobble, then consider shaved off washers as shims, or use spacers as suggested above.
GitHub
Unread 13-02-2011, 09:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Looking at the pictures, it looks like they might be springs, not washers....
