Go to Post Is this where I get to say "Mama I made it on TV?" - Pauline Tasci [more]
Unread 13-02-2011, 08:31
Geocacher Geocacher is offline
AKA: Jake Urben
FRC #3067 (Robovikes)
Geocacher is an unknown quantity at this point
FTC Motors breaking
Our team is having lots of problems with the terminals shearing clean off the FTC motors. Is anyone else having this problem? And if so how are you trying to stop this from happening?
Unread 13-02-2011, 09:06
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: FTC Motors breaking
Try not to drop them?
I was thinking about how to repair these terminals, but I fear that it would be considered a modification and make the motor illegal for competition. However, for practice, my idea was to drill a very small pilot hole next to the broken terminal in its plastic berth. Into this would go a small screw whose threads would contact the remaining metal of the tab. Electrical connection to the screw might be done by ring connector if it were on top of an insulating washer. That is, screw goes thru ring connector, insulating washer (fiber or plastic) then into pilot hole in plastic. I haven't done this yet, haven't needed to. This is only a plan, so if you try it let us know how it works. Good luck!
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 13-02-2011, 09:11
AKA: Jake Urben
Thanks for your reply. We haven't dropped them but I was looking for a way to make the posts more robust. I am not on our minibot team so I dont know a lot about our setup
Unread 13-02-2011, 09:12
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
If you are using the white terminal/wire mounts, there should be no problem with the tabs coming off. (unless you are smacking the robot on the ground). These were added last year to protect the motor tabs.
If you need to restrain the white clips, then use some velcro to keep them in place.
If you have soldered directly to the tabs, then you will have to protect the wires otherwise the terminals WILL break off. We always fold the wires back over the motor body and zip tie them in place.
If you need more protection, get some thin polycarbonate (Lowes) and cut it into a thin strip. Heat up that strip and fold it over the end of the motor.. Velcro it in pace.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 13-02-2011, 09:13
pbawesome pbawesome is offline
FRC #1100
pbawesome is an unknown quantity at this point
We have had problems internally with the motors. We let off some smoke... I'm guessing it was the coating around the magnet wire that we burned off. I think the windings are shorting within themselves, greatly reducing the resistance on the windings, and pulling so much current that it's burning off even more insulating material.
I really don't like this kit in general! It's not very good, and is very expensive. I want to try making a minibot from VEX parts to prove how much better VEX is!
Unread 13-02-2011, 09:16
AKA: Jake Urben
What mounts are you talking about? I do the vast majority of the soldering for our team and its a big problem wen they break off because we have to get another motor out and solder it and put heat shrink tubing over that.
Unread 13-02-2011, 09:55
PhilBot's Avatar
AKA: Phil Malone
The FTC kit came with two white plastic motor wire connectors (with wires attached).
You don't "have" to solder the motor wires on to the motors.
Using the connector makes it extremely easy to replace motors this way.
http://parts.ftcrobots.com/store/det...&c=1&t=0&l= 0
If you are going to solder, you MUST strain add strain relii to hese terminals.
Phil.
Phil Malone
Unread 13-02-2011, 09:57
AKA: Jake Urben
In our design we have two motors so could we order more?
Unread 13-02-2011, 10:00
There is nothing stopping you from showing how the minibot made of VEX compares to the other minibots -- it just won't be legal. Make it, prove to yourself, prove to others, suggest improvements to the kits, etc.
Greg McKaskle
Unread 13-02-2011, 10:02
PhilBot's Avatar
AKA: Phil Malone
Order more what?
Motors? Only as spares.
Connectors? Sure as many as you want.... (but you should have 2 already)
Phil Malone
Unread 13-02-2011, 10:11
AKA: Jake Urben
I meant the Motor connectors
Do you mean 2 connectors or two pairs of connectors?
Unread 13-02-2011, 10:36
FRC #2170
The FTC kit may have included these connection devices, but the Tetrix jumble that came from first choice did not. They can be ordered from pitsco. So, if you're ordering anyway, you would do better to get the connector that has thermal overload protection built into it. Not sure about how firmly that connection device fits onto the back of the motor either.
Unread 13-02-2011, 17:41
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
So far we havn't been having that problem, but we have bent three axles, burnt out one motor, and blown four fuses
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 13-02-2011, 18:00
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
We did not get any motor mounts and broke the tabs. Now we have $60 more worth of motors on order.
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 13-02-2011, 22:45
PhilBot's Avatar
AKA: Phil Malone
Hopfully you saw the motor mounts and ordered some.
Phil Malone
