Go to Post You miss 100% of the shots you don't take. - AdamHeard [more]
Unread 13-02-2011, 01:03
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Plaction Wheel?
How do we apply the tread on the wheels?
Thanks in advance.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 13-02-2011, 01:17
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: Plaction Wheel?
apple? apply?
Unread 13-02-2011, 02:33
Mk.32's Avatar
AKA: Mark
Re: Plaction Wheel?
yeah my bad..
corrected in the OP
Unread 13-02-2011, 02:38
ttldomination's Avatar
Sunny
Re: Plaction Wheel?
If you ordered the wheel with the tread, then AM fits the tread into wheel and depending on the size of the wheel, they attach the two ends of the tread.
Various teams don't approve of AM's method of attaching the two ends of tread together and teams have attached with rivets and other methods.
I suggest doing a search for plaction wheels and see if you can find the answers to all of your questions.
- Sunny
1648: 2013-2014
5283: 2015
Unread 13-02-2011, 03:06
Mk.32's Avatar
AKA: Mark
Re: Plaction Wheel?
sweet thanks.
We got some wheels from another team but without thread so looking for some info.
Unread 13-02-2011, 03:23
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
Re: Plaction Wheel?
Generally we just buy them with the tread on and then rivet it on some more (cause their staples are notoriously weak).
If you don't get them like that, you're going to have to buy tread from somewhere and the easiest way to attach it to the wheel is to drill some holes and rivet it on.
Unread 13-02-2011, 03:27
Mk.32's Avatar
AKA: Mark
Re: Plaction Wheel?
Yeah we have a roll of thread just need to attach, also how long does the thread last generally
Unread 13-02-2011, 03:34
Re: Plaction Wheel?
Depending on the type of tread and similar things, you can expect it to last up to one regional, max. You will want to have a spare set of wheels fully treaded and ready to put on the robot in case tread comes off; you can simply put another wheel on and retread the untreaded wheel at your leisure.
It's not uncommon to swap tread at the end of the day on Friday, or between qualifications and eliminations.
Unread 13-02-2011, 11:10
Sunny
Re: Plaction Wheel?
Uh...say what? Your tread standard must be significantly higher than ours. We used the same plaction wheels for three events + testing + scrimmage last year, and I'm very comfortable to say that even after all that, the tread looks like it can go another year....
- Sunny
1648: 2013-2014
5283: 2015
Unread 13-02-2011, 11:23
Re: Plaction Wheel?
Maybe tread quality has improved, or the plactions protect it better, but I do know that when 330 used tread on their wheels, we'd be unscrewing it and putting on a new belt every event or so. I've also seen tread come off mid-match; if that happens, it's a good idea to replace the tread to minimize the chance that it'll do the exact same thing the next match.
I also know that 254 likes to keep an extra set of wheels around, ready to install if tread comes off.
On our pneumatic tires, which we've been using lately, if you can get more than one event out of them, you're doing well. Those actually have a wear indicator.
